Op-Amp Integrator: Understand 10MOhm Feedback Resistor
  • Thread starter Thread starter fatalenergy
    Op-amp
The 10MOhm feedback resistor in the op-amp integrator circuit prevents a constant voltage from appearing at the inverting input, which would otherwise be integrated and lead to saturation of the op-amp. It ensures that the gain at DC is limited to 100, preventing infinite gain that could result from small input offsets. The resistor also establishes a frequency where the capacitor's impedance matches that of the resistor, allowing the circuit to function as an integrator. Removing the resistor would disrupt the intended operation and could lead to instability. Understanding these functions is crucial for deriving the transfer function and proving the integrator's behavior.
fatalenergy
Hi,
I was assigned a lab that requires me to build the attached circuit and show how the output signal is the integral of the input signal. Basically I can't understand what the function of the 10MOhm feedback resistor is. Its giving me a headache when I try to derive my proof for the integrator, and part of the lab is to explain its significance and what would happen if it were removed.
I don't know if I should be posting this in homework help but this isn't really a math question so I figured I could try here 1st.
Thanks
Try tackling the problem systematically...
Convert the circuit to the Laplacian equvilent (i.e. C becomes 1/(Cs) and derive the transfer function. The only special things you have to remember are:
a. For an ideal op-amp, the currents entering the inverting and non-inverting terminals is zero.
b. For an ideal op-amp, the voltage between the inverting and non-inverting terminals is zero.
Clue: In the s domain, a 1/s denotes an intergral.
Try this and see if it makes more sense to you.
Or that the voltage across a cap:
Vc = \frac{1}{C} \int i_c dt
The R(f)=10M\Omega resistor is there to make sure you do not have a small constant voltage on the inverted input (this would be integrated and you don’t want that). You can show that there is a frequency where the impedance of the capacitor equals the impedance of the R(f) resistor. Over this frequency the circuit acts as an integrator, so you can try to neglect that resistor in your calculations
The feedback resistor limis the gain at DC to 100. If it was not there the theoretical gain at DC would be infinit. Any small input offset would cause an integration that would eventually saturate the op amp. Then all the usual assumptions about op amps go to H@$^*.
Joe
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
