Op-Amp Integrator: Understand 10MOhm Feedback Resistor
  • Thread starter Thread starter fatalenergy
    Op-amp
The 10MOhm feedback resistor in the op-amp integrator circuit prevents a constant voltage from appearing at the inverting input, which would otherwise be integrated and lead to saturation of the op-amp. It ensures that the gain at DC is limited to 100, preventing infinite gain that could result from small input offsets. The resistor also establishes a frequency where the capacitor's impedance matches that of the resistor, allowing the circuit to function as an integrator. Removing the resistor would disrupt the intended operation and could lead to instability. Understanding these functions is crucial for deriving the transfer function and proving the integrator's behavior.
fatalenergy
Hi,
I was assigned a lab that requires me to build the attached circuit and show how the output signal is the integral of the input signal. Basically I can't understand what the function of the 10MOhm feedback resistor is. Its giving me a headache when I try to derive my proof for the integrator, and part of the lab is to explain its significance and what would happen if it were removed.
I don't know if I should be posting this in homework help but this isn't really a math question so I figured I could try here 1st.
Thanks
Try tackling the problem systematically...
Convert the circuit to the Laplacian equvilent (i.e. C becomes 1/(Cs) and derive the transfer function. The only special things you have to remember are:
a. For an ideal op-amp, the currents entering the inverting and non-inverting terminals is zero.
b. For an ideal op-amp, the voltage between the inverting and non-inverting terminals is zero.
Clue: In the s domain, a 1/s denotes an intergral.
Try this and see if it makes more sense to you.
Or that the voltage across a cap:
Vc = \frac{1}{C} \int i_c dt
The R(f)=10M\Omega resistor is there to make sure you do not have a small constant voltage on the inverted input (this would be integrated and you don’t want that). You can show that there is a frequency where the impedance of the capacitor equals the impedance of the R(f) resistor. Over this frequency the circuit acts as an integrator, so you can try to neglect that resistor in your calculations
The feedback resistor limis the gain at DC to 100. If it was not there the theoretical gain at DC would be infinit. Any small input offset would cause an integration that would eventually saturate the op amp. Then all the usual assumptions about op amps go to H@$^*.
Joe
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
