woven
- 1
Seeking opinion regarding included code.
//Processing - Processing.org
//c# wpf
It seems fairly evident that as we created the system of symbolism we should be able to manipulate it at will and yet it seems a subject little spoken of. This code is simply using addition and subtraction within the base 256, a very basic implementation yet able to convey so much.
EDIT: I leave it to you to rework the code to suit whatever form of interaction you see fit, i have implemented a simple keypress system within the processing code, the extension of which should be easy for most. One might incorporate a system of gestures or mouse interaction to enable speedy transitions.
Code:
int _size = 256;
int _mx, _my;
Ordinate _x, _y, _one;
void setup()
size(this._size, this._size, P2D);
_x = new Ordinate(this._size);
_y = new Ordinate(this._size);
_one = Ordinate.One(this._size);
void draw()
Ordinate o = Ordinate.Add(_x, _y);
for(int a = 0, x = 0, y = 0; a < o._magnitude.length; a += 3)
int col = 255 << 24 | o._magnitude[a] << 16 | o._magnitude[a + 1] << 8 | o._magnitude[a + 2];
stroke(col);
point(x, y);
x = x + 1 == _size ? 0 : x + 1;
y = x == 0 ? y + 1 : y;
void keyPressed()
if(key == 'w')
_x = Ordinate.Add(_x, _one);
else if(key == 's')
_x = Ordinate.Sub(_x, _one);
else if(key == 'a')
_y = Ordinate.Add(_y, _one);
else if(key == 'd')
_y = Ordinate.Sub(_y, _one);
void mousePressed()
_mx = mouseX;
_my = mouseY;
void mouseReleased()
int dx = mouseX;
int dy = mouseY;
int dragLength = (_mx - dx) * (_mx - dx) + (_my - dy) * (_my - dy);
static class Ordinate
public int _size;
public byte[] _magnitude;
private Ordinate()
this._size = 0;
this._magnitude = null;
public Ordinate(int Size)
this._size = Size;
this._magnitude = new byte[this._size * this._size * 3];
public static Ordinate One(int Size) {
Ordinate o = new Ordinate(Size);
o._magnitude[o._magnitude.length - 1] = 1;
return o;
public static Ordinate Add(Ordinate Ord1, Ordinate Ord2)
Ordinate o = new Ordinate(Ord1._size);
for (int a = Ord1._magnitude.length - 1, carry = 0; a > -1; a--)
int v = Ord1._magnitude[a] + Ord2._magnitude[a] + carry;
carry = v / 256;
o._magnitude[a] = (byte)(v - carry * 256);
return o;
public static Ordinate Sub(Ordinate Ord1, Ordinate Ord2)
for (int a = Ord1._magnitude.length - 1, borrow = 0; a > -1; a--)
if (Ord1._magnitude[a] >= (Ord2._magnitude[a] + borrow))
o._magnitude[a] = (byte)(Ord1._magnitude[a] - Ord2._magnitude[a] - borrow);
borrow = 0;
else
o._magnitude[a] = (byte)((Ord1._magnitude[a] + 256) - Ord2._magnitude[a] - borrow);
borrow = 1;
return o;
//c# wpf
Code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
namespace Ordinate
public partial class MainWindow : Window
Ord _x, _y;
internal class Ord
private int _size;
private byte[] _magnitude;
public byte[] Magnitude { get { return _magnitude; } set { _magnitude = value; } }
public static Ord One(int Size) { Ord o = new Ord(Size); o._magnitude[o._magnitude.Length - 1] = 1; return o; }
public Ord(int Size)
this._size = Size;
public static Ord operator +(Ord Ord1, Ord Ord2)
if (Ord1._magnitude.Length != Ord2._magnitude.Length)
throw new ArgumentException("Operands must have equal dimensions");
Ord o = new Ord(Ord1._size);
for (int a = Ord1._magnitude.Length - 1, carry = 0; a > -1; a--)
carry = v / 256;
return o;
public static Ord operator -(Ord Ord1, Ord Ord2)
for (int a = Ord1._magnitude.Length - 1, borrow = 0; a > -1; a--)
borrow = 0;
else
borrow = 1;
return o;
internal static BitmapSource Render(Ord Ord1, Ord Ord2)
WriteableBitmap buffer = new WriteableBitmap(Ord1._size, Ord1._size, 96, 96, PixelFormats.Rgb24, null);
buffer.Lock();
buffer.WritePixels(new Int32Rect(0, 0, Ord1._size, Ord1._size), (Ord1 - Ord2)._magnitude, Ord1._size * 3, 0);
buffer.Unlock();
return buffer;
public MainWindow()
InitializeComponent();
private void Window_Loaded(object sender, RoutedEventArgs e)
_x = new Ord(256);
_y = new Ord(256);
renderBuffer.BeginInit();
renderBuffer.Source = Ord.Render(_x, _y);
renderBuffer.EndInit();
