Opposing forces but opposite travel = no work?
Two objects with opposing forces can indeed travel in opposite directions while doing work, as work is defined as a force applied over a distance, not just net displacement. In the example provided, both boxes experience positive work when pushed in their respective directions. However, when they are returned to their starting positions, the overall work done becomes zero due to no net displacement. The discussion highlights that while work can be done in both directions, the presence of friction complicates the scenario, as it introduces non-conservative forces. The inquiry concludes with a question about the mechanical possibility of stopping both boxes from doing work entirely.
CountFleet
Hi, This is something I was wondering about. Can two objects with opposing forces travel in opposite directions without any work(minus friction)? I made a drawing in pdf format to demonstrate what I'm trying to say. My understanding of physics is pretty elementary so I apologize if this is a stupid question.
Work is equal to a force applied over a net distance (aka displacement) . Net distance is the difference between your starting and ending point. So if you push a box from point A to point B, and then push it back from point B to point A, no work will be done.
In your diagram, for part 1, it looks like the first box is being pushed to the right by a force pointed to the right, so positive work is being done on that box. The second box is being pushed to the left by a force pointed to the left, so the work being done on that box is also positive. It doesn't matter if the boxes are going in different directions, they are both being moved with positive work.
however, in your second part, it looks like you push the boxes back to their starting positions, so the overall work for the first and second part would be zero since the boxes don't have a change in displacement.
This is incorrect. Work is a force applied over a distance, NOT a force applied over a net distance or displacement. If your force is conservative then the difference is moot, but in the case of friction where the force is not conservative then the difference is very important.
In your diagram both boxes are DOING work.
I was wondering if it was mechanically possible to stop both boxes from doing work?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
