Oppositely charged parallel plates I don't get why
The discussion centers on the forces acting on a charge placed between oppositely charged parallel plates. It highlights that the net force on a charge varies depending on its position between the plates, questioning the application of Coulomb's law. Participants clarify that since the charge on a plate is not a point charge, integrating over the plate is necessary for accurate calculations. They suggest using Gauss' law for infinite plates to simplify the analysis and provide mathematical derivations for electric field strength. The conversation concludes with an acknowledgment of the insights gained regarding the complexities of electric fields from charged plates.
foxx38
"the sum of the force from the top plate and the force from the bottom plate always equals the same amount"...as shown here:
http://www.regentsprep.org/Regents/physics/phys03/aparplate/
I mean, if a charge was placed at different places (ie distances) between 2 point charges, the net force would not be the same?
Am I using Coloumb's law incorrectly?
For example, let the charge be q and the distance between them be 4r, then if the test charge is placed half way between them, the net force would be
kq²/(2r)² + kq²/(2r)²
and if the test charge is placed at 1/4 of the distance (ie at r), then the net force would be...
kq²/(r)² + kq²/(3r)²
Any/all help/enlightenment would be appreciated. :)
The charge on a plate is not a point charge. If you want to use Coulomb's law you will have to integrate it over the plate. Of course, for a very large (infinite) plate you can use Gauss' law much easier.
oop.s. I meant Coulomb's law.
Thanks...are you saying that if we treat each plate as an infinite number of point charges and use Coulomb's law an infinite number of times to find the sum(s) (as in an intergral) they will balance each other? Could you show/tell me the intergral(s) please?
btw...How would you explain this without knowledge of intergrals? :)
I'm not sure this can be done without integrals. Also instead of an infinite number of point chargers, which would be infinite charge, you have a finite amount of charge per unit area from a infinite large disk or plane.
The math for field strength from a solid disc is explained here:
http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/elelin.html#c3
as R^2 \ \rightarrow \infty
then \frac{z} {\sqrt{z^2 + R^2}} \ \rightarrow \ 0
and you end up with E_z = k \ \sigma \ 2 \ \pi
An alterative approach is to consider the field from an infinitely long line (= 1/z), then integrate an infinitely large plane composed of infinitely long rectangles that approach infinitely long lines as their width approaches zero.
For an infinite line charge, E = 2 k λ / r, where λ is charge per unit length and r is distance from the line. Here is the derivation:
http://hyperphysics.phy-astr.gsu.edu/%E2%80%8Chbase/electric/elelin.html#c1
For an infinite plane case, infinitely long strips (rectangles) approximate a line as their width -> 0. The area of a strip of lengh L is L dx, and the charge dq = σ L dx. The charge per unit length dλ = dq/L = σ dx. Assume the plane exists on the x-y plane, then the magnitude of the field at any point in space from a strip is dE = 2 k σ / r, where r is the distance from a strip to that point in space. In the case of the entire plane, the x components cancel because of symmetry, with only a net force in the z direction, and for each strip of the plane, dEz = dE (z / r) = dE sin(θ).
E = 2 k \sigma \int_{-\infty}^{+\infty} \frac{{sin}(\theta)dx}{r}
{sin}(\theta) = z / r
E = 2 k \sigma \int_{-\infty}^{+\infty} \frac{z {dx}}{r^2}
r^2 = z^2 + x^2
E = 2 k \sigma z \int_{-\infty}^{+\infty} \frac{dx}{z^2 + x^2}
E = 2 k \sigma z \left [ \frac{1}{z} tan^{-1}\left (\frac{x}{z}\right )\right ]_{-\infty}^{+\infty}
E = 2 k \sigma z \left ( \frac{1}{z} \right) \left ( \frac{+ \pi}{2} - \frac{- \pi}{2} \right )
E = 2 \pi k \sigma
thanks...you've (both) given me a lot to go on...will do :)
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
