Optical tweezers, QPD back focal plane interferometry vs imaging
The discussion centers on the use of a 10x infinity objective as a condenser in optical trapping setups, specifically comparing imaging techniques and back focal plane interferometry (BFPI). BFPI allows for the measurement of sub-resolution motion of particles by imaging the back focal plane of the objective onto a detector. The method involves inserting a relay lens to capture the interference pattern at the exit pupil of the condenser lens. This technique can provide advantages for cell or vesicle-level work, particularly in data processing methods like power spectrum calibration. Understanding BFPI is crucial for enhancing measurement accuracy in optical trapping applications.
donroy81
Hello, I use a 10x infinity objective as a condenser in a optical trap setup. The collimated forward scattered light is then focused with a 40mm lens onto a QPD. This is the imaging techqnique. There is also BFPI, and I am not clear on this method. My understanding is that I need to image the back focal plane of the 10x infinity objective by inserting another lens. Then use the 40mm lens to image onto the QPD. For cell/vesicle level work ( not single molecules) what advantage does this bring? More importantly, does the data processing change? I use the power spectrum method to calibrate.
Science news on Phys.org
What does 'BFPI' stand for, and can you provide a reference for it?
Hello,It stands for < a href="http://biopt.ub.edu/force-detection/back-focal-plane-interferometry"> Back focal plane interferometry </a>.
Oh, ok- the back focal plane (technically, it's actually the exit pupil) of the condenser lens is where the interference pattern is; the relay lens images the back pupil plane onto a detector. The advantage is that sub-resolution motion of the particle can easily be measured with interferometry.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
