Optimization Problem Homework: Find Largest Positive Number
  • Thread starter Thread starter Lorek
    Optimization
7 replies · 2K views
Lorek
Find the positive number that exceeds its square by the largest amount. Obviously this is on the open interval (0,1).
[tex]F(x) = ( \frac{1}{n} ) ^2 - n \Rightarrow F'(x) = \frac{-2}{n^3} - 1 = 0<br /> \Rightarrow 1 = \frac{-2}{n^3} \Rightarrow n^3 = -2[/tex]
This is where I'm stuck. Taking the Cubic Root of a Negative number only nets
me a complex number. The answer at the back says its 1/2.
Hi Lorek! :smile:
why are you using 1/n2 instead of x2 ?? :confused:
but if you must, you should use 1/n also, not n :wink:
I don't understand why you need to use [tex]\frac{1}{x}[/tex] instead of x.
Its asking for the positive number that is greater than its square at its maximum.
[tex]x^2 = x[/tex]
Since its number can only be greater than its square as a fraction I used (1/x)^2.
Your saying I should set it up as
[tex]\frac{1}{x^2} - \frac{1}{x}[/tex] ?
I don't understand why though.
Hi Lorek! :smile:
Sorry, I don't understand any of your reasoning. :redface:
It's much easier to use the number x itself than its reciprocal, ie to differentiate x2 - x …
if you must use the reciprocal, y = 1/x, then it's 1/y2 - 1/y …
you'll just have to think about this until you see it :smile:
We're looking for the largest number x that is greater than its square.
Setting the problem up as [tex]x^2 -x[/tex] and then differentiating says its maximum
is at 1/2.
The problem I see with that setup is if you take 0.99 and square it you get .9801. (original number larger than its square)
0.99 is larger than 1/2 (0.5).
Since we're looking for the largest number x that is greater than its square, and .99 falls into that category seeing as .99^2 = .9801.
0.99 > 0.9801 so it qualifies. Shouldn't the answer be The limit as x -> infinity of 1/1+(1/x).
x^2 = x. We're looking for the largest number that that holds true.
rearranging we got x^2-x = 0.
Plugging in 0.99 to x nets us:
0.99^2 - 0.99 = -0.0099 (not quite 0 but pretty close)
Since -0.0099 != 0 that's a problem.
.5 ^2 - .5 = -.25
-.25 != 0. (no where near 0).
The closest number which gets to x^2 = x is [tex]\lim_{x \rightarrow \infty} \frac{1}{1 + \frac{1}{x}}[/tex]
Update: I'm heading into bed. I'll just ask my math teacher when I see him tomorrow. Its a tough problem for being problem #1 in the book.
No, you're looking for the largest value of x - x2.
