Orbit of figure eight 3 or more bodies
To set up initial conditions for a three-body figure-eight orbit, specific position and velocity vectors must be defined for each body, along with their respective masses. The governing equations involve the force equations f=mi*x'' and f=SUM(mi*mj*r/|r|^2), which lead to a differential equation for the system. The discussion references additional resources for further understanding and examples of similar orbital simulations. The links provided lead to a website with detailed information on orbits and previous discussions on the topic. Understanding these principles is crucial for accurately modeling the dynamics of a three-body system in a figure-eight formation.
renegade05
If I wanted to set up some initial conditions for a 3 body figure eight orbit, what would I have to set the position and velocity vectors?
Say I have three vector inputs:
initial position <x,y>
initial velocity <x,y>
mass of bodies <m1,m2,m3>
The solutions for position use
f=mi*x''
and equating the two to get a differential equation.
Hope this make sense.
See this for a reference of what I am trying to do:
http://www.ams.org/samplings/feature-column/fcarc-orbits3
We discussed this on my website. You can find some info here:
http://www.orbitsimulator.com/cgi-bin/yabb/YaBB.pl?num=1181200864/0
http://www.orbitsimulator.com/cgi-bin/yabb/YaBB.pl?num=1250625868/0#0
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
