How Can You Distinguish Between Propanone and Propanal?
To distinguish between propanone and propanal, the Tollens' reagent test can be used, where only propanal will produce a silver mirror. Propanone reacts with hydrogen cyanide to form a cyanohydrin through nucleophilic attack on the carbonyl carbon. Sodium borohydride reduces propanone to an alcohol, with the mechanism involving nucleophilic addition due to the electrophilic nature of the carbonyl group. The discussion also highlights that all isomers of C4H8O react with 2,4-dinitrophenylhydrazine, but only aldehydes react with Tollens' reagent. The conversation emphasizes the importance of understanding the reactivity of aldehydes versus ketones in these tests.
nathaniell
1)Give a chemical test that can be used to distinguis between separate samples of propanone and propanal. Give a suitable reagent for the test and describe what you would obsrve with propanone and with propanal.
2) Outline the reaction of propanone with the following reagents. Give the equation for the reaction, the conditions, and the name of the organic product.
(i)Hydrogen cyanide
(ii)dodium tetrahydridoborate(III) (sodium borohydride)
(iii)what type of mechanism is this
(iv) what feature of the carbonyl group makes this type of mechanism possible? Explain how this feature arises?
3)Three isomers A,B, and C have the molecular formula C4H8O. All three compouds give an orange precipitate with 2,4-dinitrophenylhydrazine reagent. B and C give a silver mirror when waremed in ammoniacal silver nitratesolution. Write the strcutural formulae of A,B and C.
You need to show some work before we will help. What have you tried with this problem?
My idea to the separate samples of propanone and propanal is to use an ammoniacal solution of silve which propanone should show some change(a white precipitate) and propanal does not
While when propanone reacts with hydrogen cynaide the N-bonds will break and will be attached to propanone
While the last one I have had no ideas
Youre right on the tollens reagent test. Propanal will also give a red ppt with benedicts solution and felhings reagent (of Cu2O).
On the cyanide reaction, the N-bonds won't break, CN- will act as a nucleophile and attack the carbonyl carbon to form a cynohydrin.
The NaBH4 will reduce it to alcohol, but I don't know what mechanism makes it possible.
For the last one, if they give red ppt with 2,4-DNP, then they have a hydroxy group (OH). If they react with tollens reagent (ammonical silver nitrate), then they are aldehydes.
You have that backwards. Only aldehydes react with the Tollens reagent.
nathaniell said:
...While when propanone reacts with hydrogen cynaide the N-bonds will break and will be attached to propanone
What is name of the product of cyanide reacting with a ketone?
The last question only distinguishes the aldehydes from the ketones. All will react with 2,4-DNP but only an aldehyde(s) can react with the Tollen's reagent. Obviously there are two isomers of aldehydes with the empirical formula C4H8O. Can you draw the two isomers?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
9K
