I Orientation of the Earth, Sun and Solar System in the Milky Way
The discussion focuses on the motion of the solar system within the Milky Way and the relationships between celestial, ecliptic, and galactic coordinate systems. Diagrams illustrate the solar system's position, showing it approximately 50 light years above the galactic plane and detailing the angles between various celestial planes. Participants provide feedback on the diagrams, suggesting terminology corrections and clarifying the inclination of the Moon's orbit relative to the ecliptic. The conversation also addresses the solar system's clockwise motion around the Milky Way and the orientation of Earth's hemispheres in relation to this motion. Overall, the thread emphasizes the importance of accurate representation and understanding of astronomical coordinates and movements.
  • #101
phyzguy said:
I keep pointing out that the sun's motion around the Milky Way is not an "orbit" in the sense that we usually think of it. It is not even a closed curve. Orbits in a central potential like the solar system are closed curves, but orbits in a potential well like the Milky Way's are typically not. Even if the Milky Way's potential were static in time the orbit would not be a closed curve, and it is definitely not static in time. So it is best to think of the sun's motion as an approximate orbit, where each path around the Milky Way is a different curve.
No argument there - I agree that the sun won’t return to the same place in another 230 million years or so for the reasons you have noted. “Approximate orbit” is a more accurate term than just “orbit.” In a sense though, the Earth doesn’t return to the same spot either after one trip around the sun since it is moving through both space and time.
I have amended my diagram so that it doesn't show the sun’s orbit as a closed curve.
But the original intent in my previous post was to point out that the sun moves in unison with our rotating galaxy - not against it, and that its up and down motion is relatively very small.
Astronomy news on Phys.org
  • #102
rootone said:
While the galaxy does have an overall angular momentum, which the solar system goes with,
This is not like a planet orbiting a star, whose motion is highly predictable.
Predictability is something that people tend to assume and we have had a very short fraction of a period in which to observe any motions outside the Solar System. We have been making 'fairly' accurate observations for less than a hundred years yet making predictions about many thousands of years in the future. They must be a bit speculative, surely.
Even motion within the Solar System is subject to Chaos so I have to wonder about the accuracy of predictions with the galactic many-body problem.
(Not that it really matters to us, of course.)
  • #103
fizixfan said:
I've been tinkering with a few diagrams in an attempt to illustrate the motion of the solar system in its journey around the Milky Way. I also wanted portray how the celestial, ecliptic and galactic coordinate systems are related to each other in a single picture. Note: in the Celestial, or Equatorial system, the Celestial North Pole (an extension of the Earth's axis of rotation), uses the default setting of North as "up." The Ecliptic and Galactic also use North as "up" with reference to the Celestial North Pole. Some people say that in space there is no such thing as "up" or "down," but in determining the position of a celestial object (e.g., declination and right ascension of a star or deep-sky object) is DOES matter.
Please have a look at these diagrams and feel free to comment on any errors, or make suggestions as to how I could make them better. I drew these images, but anyone is free to re-use them without restriction.
Figure 1 shows the motion of the Earth and Sun around the Milky Way. The solar system is actually well within the galactic disk, which is about 1,000 light years thick. The sun and the planets that circle it is roughly 50 light years above the galactic plane, and passed northward through it about 3 million years ago in its undulating path around the galactic center. Note: this diagram is not to scale. The northernmost excursion of the solar system takes it about 250 light years above the galactic plane. This means it would only subtend an angle of about 0.55° relative to the galactic center.
Figure 1. Motion of Earth and Sun around the Milky Way
Figures 2. and 3. show the orientation of the Earth, Sun & Solar System in the Milky Way - similar diagrams, just presented in different ways.
Figure 2. Orientation of Celestial, Ecliptic and Galactic Poles and Planes
Figure 3. Orientation of astronomical coordinates projected on the Celestial Sphere.
View attachment 107280The angle between Celestial Equator (an imaginary plane passing through the Earth's equator) and the Ecliptic Plane (an imaginary plane extended through the Sun's equator) is 23.4°. The angle between the North Celestial Pole (an imaginary line extending through Earth's axis of rotation) and the North Ecliptic Pole (an imaginary line extending through the Sun's axis of rotation) is the same - 23.4°. This is the familiar value for the "tilt" of the Earth in its path around the Sun.
The angle between the Ecliptic Plane and the Galactic Equator (an imaginary plane passing through, and parallel to, the disk of the Milky Way) is 60.2°. The angle between the North Ecliptic Pole and the North Galactic Pole (an imaginary line extending through the Milky Way's axis of rotation) is also 60.2°.
The angle between the Celestial Equator and the Galactic Equator is 62.9°, as is the angle between the North Celestial Pole and the North Galactic Pole.
These three angles = 23.4°, 60.2° and 62.9° cannot be shown or calculated in two dimensions, because they represent separate planes which do not intersect at a common point. If you look at Figure 3, you can see that this is so.
References:
https://en.wikipedia.org/wiki/Celestial_coordinate_system#Galactic_system
https://www.eso.org/public/news/eso0932/
http://www.engineeringanddesign.com/1/054.htm
I believe this is why we have shorter days in the winter but the moon is out longer at night and the opposite in the summer. Thoughts?
  • #104
The relative angles of the Earth’s tilt and the plane of the Moon’s orbit are only affected very slightly by our Galactic situation. The height of the Moon in the sky over the year doesn’t change a lot. In winter, the Moon is seen for more hours against a dark sky than in summer. Is that what you mean by “out”? A ‘pale’ moon can be seen in a light sky in summer for many hours.
Likes Cataclysmo and davenn
  • #105
Thanks for your response. Yes the big picture of this thread is in regards to the position of the solar system relative to the mid plane of the Galaxy. I hope this discussion is still relevant and not deviating too far.
I'm focusing in on the celestial plain and lunar plain relative to earth. It seems the celestial plane and lunar plain are tilted in opposite directions leading to the trend of the Moon passing higher through the sky during winter nights and the sun passing lower in the sky during winter days. Yes, like you said longer hours of moonlight in the winter. I'm speaking from a northern hemisphere reference and also I'm curious if this is naturally also applicable for the southern hemisphere? Hope this isn't coming across as a homework question but actually as in sincere curiosity the heavenly bodies.
Kindest Regards
  • #106
Kindest Regards
If I may correct my terminology stating the lunar plane and Celestial plane are tilted in opposite directions is not very well worded. Basically I'm just saying the lunar plain is tilted higher than the celestial plain ( speaking from a northern hemisphere Viewpoint near winter solstice). I sure could use a better way to word that.
  • #107
The Moon's orbit has to around the CM of Earth / Moon so the plane must go through the middle. I think that implies that the effects are the same, top and bottom.
Edit: I think that comment needs to be modified to include the idea of 'average over time'.
  • #108
"Tilted higher" is a bit of an arbitrary statement. The Moon's orbit is tilted at 5 degrees to the ecliptic (the Earth solar orbit plane). The Moon's orbit also has a nodal precession; It "wobbles". The period of this precession is 18.6 years. This, in turn means that the Lunar orbit varies from being 18.5 to 28.5 degrees in tilt with respect to the celestial equator over that 18.6 year period.
While in one year, at the winter solstice, the Lunar orbit will align so that the full moon can appear higher in the Southern sky (as seen from the Northern hemisphere) than the Sun does on the Summer solstice(The difference between maximum and minimum declination will be the greatest), 9.3 years later, the full moon will never get as high in the sky as the Sun does on the Summer solstice (the difference between declinations will be the least).
Likes Cataclysmo and Klystron
  • #109
Whoa! That's a lot of wobble! I had no idea the Moon's orbit varied its tilt by 10 degrees.
Any idea where we are in the cycle now?
  • #110
The moon's orbit is always inclined by 5 degrees relative to the ecliptic plane. It's just that as it precesses, the inclination to the Earth's equatorial plane ranges from 23.5-5=18.5 to 23.5+5=28.5.
Likes phinds, Cataclysmo and Drakkith
  • #111
Thank you for the feedback I enjoy being an ambassador of this knowledge to my friends and family. Two nights ago we were at the beach early in the morning and I was describing the beginning of the perseid meteor shower when we saw a red fiery meteor shoot overhead. It was about a spaghetti noodle wide with a tail about 20 degrees in arc length. I will study the main thread further.
Cheers.
If your plan is for one year plant rice. If your plan is for ten years plant trees. If your plan is for one hundred years educate children.
Confucius
Likes sophiecentaur
  • #112
The Elegance of this description will make teaching others more efficient thank you.
  • #113
fizixfan said:
I have always imagined that the Sun revolves around the galaxy in a counterclockwise direction assuming the convention of looking down on it from "North" (i.e. moving to the right in typical pictures).
I never made the connection to the fact that the spiral arms spin out clockwise (as seen from the North/top).
You learn something new every day.
  • #114
Oh, for a 3D video representation of the entire shebang. . . and (in my case) the 3D means to view it :woot:
  • #115
It's worth while pointing out that the arms are not spinning like a Catherine Wheel Firework. They are just a density pattern or wave due to the interaction of each star with its 'close' neighbours. Density waves do not consist of the same stars all the time and do not travel at the same speed as their constituent stars so they can be looked upon as 'virtual'. Wiki gives a fair description of the effect.
Likes anorlunda, Cataclysmo, diogenesNY and 3 others
  • #116
Excellent explanation and animations.
  • #117
That is neato-keen! Almost obvious (particularly the _winding effect_) if you stop to think about it, which I confess I have not until I read the wiki article.
diogenesNY
  • #118
This is Venus, high in the morning sky, amid the faint pillar of light called the Zodiacal Light. The glow is sunlight reflected off cometary dust in the inner solar system.
Above is the centre of the Galaxy area of Sagittarius. Alan Dyer
https://amazingsky.net/2014/04/06/venus-in-the-zodiacal-light/
Since the Zodiacal Light lies in the ecliptic plane, we can see from this image that the plane of the solar system intersects the galactic centre.
(PF doesn't want to insert the image today.)
  • #119
Likes DaveC426913
  • #120
This is my "map" of the solar system with the orbits to scale. I have included the orbits of eight planets plus that of Pluto and the parts of Eris' orbit that falls into the frame. I will add some labels and a wire coming out of the map to indicate the passage of the system around the centre of the Milky Way. I'll also post a shot of the inner planets orbits as they are rather small in this picture.
Likes Klystron and Drakkith
  • #121
fizixfan said:
Thanks Janus - I knew the moon's orbit was inclined relative to Earth's equator, but I didn't know it was inclined TOWARD the ecliptic. Interesting! I've included your suggestion in my diagram, which also includes phyzguy's suggestion. Really appreciate the input, hope this diagram isn't getting too busy.
That is a great modification. I think these diagrams are great at explaining what can be very complex as all these planes are at different angles to each other and hard to present in a way that makes sense in a 3D way. Great work, I am going to share these with a budding astronomer in the family. Thank you.
  • #122
Wow. Great work. I was trying to do this in my head and it made my head hurt.
  • #123
Going back to fizixfan's first post and diagram, there were some comments about the solstices and equinoxes. I think that in that first diagram the solstices should be where the equinox labels are and vice versa. By the way why is fizixfan's name now struck through? Has he left the group?
  • #124
Let's just say that he went from bad to worse in his behavior at PF over the 4 years that he was here, and by the end it was obvious that he had to leave. You won't see most of the worst of his posts, since they were obviously deleted.
  • #125
Earth's equator from center 29°, planetary orbit 5.5° from center, 29-5.5=23.5
Planetary orbit backside of zodiac 52.5°, Earth's equator 29°, 52.5-29=23.5
  • #126
Great diagram of the orientation of the celestial orbit to the galactic plane. However as a Southern Hemisphere dweller this appears to me to be a diagram that will be more correct in about 120 million years when the sun has orbited around the galactic centre so that the north pole is then facing galactic centre. Currently the south pole does hence the better view of the galactic centre from the southern hemisphere. If you move your earth orbit to the left of galactic centre then it will be correct.
  • #127
It's not immediately obvious from a 2d picture where the arrows are supposed to point in 3d space, but if you look closely at the markings on the Earth's orbit, you'll notice that it's drawn near to the winter solstice. As such, the northern hemisphere is in fact intended to be facing away from the Sun, and the galactic centre.
  • #128
10/10 for the 'enlightenment' style addition to your wall. I am all in favour for that sort of thing. I have a rather naff form of sun dial which is also a good conversation piece in the garden. There are some problems with the information that these models provide. I have vague plans to make my own orrery (you can buy kits, of course) but even the posh one (below) pays no atttention to scale. (Whipple museum, Cambridge). You would need to go outside every so often to alter the lengths of your proposed wires as the years progress. Everything is on the move constantly - even Polaris will be in the wrong place with a thousand years or so.
Kepler calculated that the planets orbit at different rates so the layout will always be on the move and your version may be nearly correct for once in a few thousand years (a stopped clock is right twice a day). Also, the actual distances (as the crow flies) do not represent how hard it would be to get from one planet to another. The energy bill for interplanetary missions varies a lot and we need to use tricks ( slingshot orbits ) to go further than Mars. You'd think that 'dropping down' to reach Venus or Mercury wouldn't be too heavy on fuel but, in fact, getting closer to the Sun involves a huge amount of 'retro' energy and that has to involve many passes close to Venus for it to kill out orbital energy.
I'd love to think of a representation of the relative efforts needed for Solar System trips between planets. It's to do with cost - benefit which is why Venus (boring and totally hostile) gets few visiting missions.
It's really good to consider the dynamic nature of ther Cosmos and to get in proportion the actual timescales involved in the fanciful ideas for manned trips out there. Colonising? They are having a laugh, IMO.
Likes collinsmark and Drakkith
  • #129
I just put a bird feeder / sundial up this week. Ripped it down off the side of the house and mounted it horizontally at the back of my yard.
I have to position it correctly and secure before I put the markings on it, but for now it's holding water.
DIL suggested it needs a little water pump and a birdcam mounted in the antenna.
Oh. Right. And I have to convince my wife it doesnt make us look like trailer trash. Which makes it technically A Conversation Piece, yes.
  • Haha
Likes sophiecentaur, Imager and berkeman
  • #130
have been amused that the new selling point for SKY TV is that you don't need a dish. I never did get one.
Your dish won't have a water collection problem unless you are equatorial sited. But you can drill a hole at the lowest point.
As we're starting on show and tell . . . . .(It's about 18.00)
Cheers
  • #131
Wow, I never saw one vertically mounted! Verrrrry cool!!! Did you make it?
  • #132
It's an Armillary Style. (Posh ones cost a lot!!) I started with an old bicycle wheel (a good circle) and made a semicircular band with the same radius as the bike wheel. . The long rod (the gnomon) points N-S and you get a shadow at right angles to the time scale for all seasons when it's lined up properly. (Sun high or Sun low). Apart from the hour change in spring and autumn it's easy to read throughout the year (except when the Sun dips low during the summer.
It hasn't needed winding once!!
Likes Imager and collinsmark
  • #133
I have a related question about the lunar declination with respect to celestial latitude, i.e. tracking the moon instead of a satellite. The declination goes from +/- excursions with a period of 27.2122 days and then slowly evolves between maximum excursions (max lunar standstill) at a period of 18.6 years (the precessional cycle of the lunar nodes). This becomes a trig sinusoidal expansion of the main period of 27.2122 days (aka the draconic period) with two sidebands. One is 27.3216 days (aka the tropical period) and the other is 27.1036 days. What is that latter period called? I can't find reference to it anywhere.
Interesting too is the etymology, as the sidebands are often referred to as satellite sidebands, which is not literal but more figurative in the sense that they are in proximal orbit to the main frequency. So that 27.3216 day would be the - sideband (slower frequency) while the 27.1036 day is the + sideband (faster).
  • #134
Can you rotate the scale to deal with that, or do you just have to remember to correct for BST?
The dung beetle gets pretty tired though.
  • #135
This is normal terminology for a spectrum with one major component and identifiable groups of low level spectral components above and below the main component. The spectrum of narrow band phase modulation (in RF signalling etc.) has readily identifiable side bands. When the phase of a carrier wave varies by only a few tens of degrees (+/-) the sidebands look symmetrical. If a satellite is in orbit and is regularly disturbed by the presence of a nearby satellite you have the right sort of conditions to be described as phase modulation.
  • #136
The scale can be rotated around the gnomon by releasing a clamp. Also, because of the oddities of the Earth's spin and solar orbit, the actual angle varies over the year. I sort of planned to adjust the scale on a weekly basis, to take care of that but, I actually don't bother to compensate for 'The Equation of Time' (Law of diminishing returns). Google "Analemma" for some nice images.
  • #137
I haven't thought it through, but I was surprised it flips in the southern hemisphere.
  • #138
It's not a 'positional' thing; it's a timing thing. You are so luck that there's such a lot of graphical help with these problems compared with the 60s.
1. The Earth's orbit is an ellipse (as with all orbiting bodies in practice)) and that means its angular speed varies. So the Sun is not overhead in exactly 24 hour steps; observed time is gained and lost on the way round.
2. The tilt of the Earth's axis distorts has another effect on observed noon time. The two variations are not in phase so the crossover of the figure 8 on the analemma is not half way up. The crossover depends on relative phases and not where you're looking from (North or South) a few thousand km compared with 150 million km distance to the Sun.
The graph of equation of time shows those two distinct components of the overall variation with time.
Nothing up there has fixed periods and one variation will drift in phase. There is a clear four year cycle in the equation of time but other perturbations mean no four year groups are the same.
  • #139
Thanks for the clarification as to the origin of satellite subbands, as they do seem to associate with a cyclic "orbit" perturbing a primary cycle.
Still don't have an origin story for the unnamed +subband I was asking about. One place it may come up is in long-period tidal excursions. In the Bay of Fundy, where the most extreme tides occur, there's a maximum excursion that is large enough to fill up surrounding marshes every 4.53 years1. I can calculate this number directly from the interference of the perigee/anomalistic cycle of 27.5545 days with the unnamed 27.1036 day cycle. 1/(1/27.5545-1/27.1036) = 1656 days = 4.53 years
What this implies is that the fast +sideband of the moon's declination cycle is amplified by the stronger lunar force as the moon nears the Earth during its perigee/apogee cycle. The slower -sideband amplification results in the 8.85 year cycle, which is called the apsidal precession cycle. So again this -sideband cycle has a name but the 4.53 year cycle doesn't. Both of these (27.1036 day and 4.53 year) probably should have a name, as there are names for many of the eclipse cycles.
1 Desplanque, Con, and David J. Mossman. "Tides and their seminal impact on the geology, geography, history, and socio-economics of the Bay of Fundy, eastern Canada." Atlantic Geology 40.1 (2004): 1-130.
  • #140
The arms are 'just' density waves, in which some stars are closer together and others are further apart. All (most) stars at a given radius have similar speeds in the same sense. The arms are 'virtual' objects (not sure if that's the right term) but they move through the positions of the stars (and will contain a different set of stars over time). This is the same as with sound waves, in which the air molecules themselves do not travel far during a second but the sound travels 330m.
The stars' orbits perturb each other in a form of resonance - as do satellites round the Earth - although their mean speeds are all much the same.
Likes collinsmark and DaveC426913
  • #141
Yeah. Density waves. Where they bunch up together, like sound waves.
  • #142
What is intriguing about this 4.53 year cycle is in how it gets conflated with the half-8.85 year cycle, which being 4.4 years is close to 4.53. There are many references to extreme tidal cycles being dominated either by (1) the 18.6 year nodal declination cycle or (2) the 4.4 year half-perigean cycle. So one is a moon declination effect and the other is a moon distance effect. But that specific 4.4 number never made intuitive sense, in that how can extreme tides occur due to both an apogee and a perigee? I think it gets explained as a precession of the apsides, in that an additional apogee occurs when the moon is on the opposite side of the planet from where the strongest direct apogee is. So the moon "sees" through the earth, or if tidal forces are partially tangential and thus tractive to the surface, an apogee would alternate on each horizon. This also means that the 27.5545 day anomalistic period has a virtual harmonic at 1/2 that cycle. One such recent reference is an article on nuisance flooding (NF) 1
The role of long-period tides in modulating NF frequency​
In addition to secular changes in NF frequencies due to tidal changes, we also detect a ~4.5-year cycle in the time series of additional/reduced NF days (fig. S3), which is close to the half perigee cycle that modulates tides at a period of 4.4 years. The perigean (4.4 years) and nodal (18.6 years) modulations of tides affect high water levels (10). We quantify the impacts of these cycles on NF events by removing them from the tidal prediction and recalculating the number of NF days (assuming that these cycles would not exist); this is only done for the dataset with the observed tides, not the one with historic tides, as we assume that changes in the amplitudes of the 4.4- and 18.6-year cycles were negligible. The oscillations in NF days due to the low-frequency tidal modulations are evident, and their influence increases over time (Fig. 4D). The 4.4-year cycle adds up to 20 NF days across all locations (Fig. 4D) when it peaks under present-day sea level, whereas the 18.6-year cycle causes an additional 30 NF days during its peak compared to average conditions (Fig. 4D)
Like the Bay of Fundy example I referenced above, the consensus theory says 4.4 years, but the measurements are closer to 4.5 years. The behavioral difference between the two is that 4.5 years includes both declination and perigee wheres 4.4 years is just perigee.
I guess what I find odd about this is the disparity in precision and detail for this attribution in contrast to the incredible detail needed for total solar eclipse calculations. Consider the grade school science teacher that promised his class in 1978 that they would meet up again in 2024 to watch the eclipse near their school location in upstate New York -- and they did just that. Incredible precision needed for that.
Another piece of evidence is the plotting of data from the JPL Horizons on-Line Ephemeris System. I didn't create this plot (courtesy of Ian Wilson) but I don't doubt that it is correct, since the JPL tool is used for satellite orbit modeling.
1 Sida Li et al.,Evolving tides aggravate nuisance flooding along the U.S. coastline.Sci. Adv.7,eabe2412(2021).DOI:10.1126/sciadv.abe2412
  • #143
I tried recreating this chart I posted using the online NASA JPL Horizons ephemeris program, but couldn't duplicate the 4.53 year modulation cycle that Ian Wilson had managed to find.
What I always find is the 4.42 year modulation by multiplying the absolute value of the lunar declination cycle by the R lunar distance. This develops the beat 2/27.3216 - 2/27.5545 = 1/(365.242*4.425)
Declination of the moon with respect to the equator is different than with respect to the obliquity of the earth's rotational axis to the earth's orbit around the sun. IOW that's with respect to the ecliptic plane -- and when the moon crosses that leads to total solar eclipse cycles like we had in the USA the other week
The beat frequency when interacting with the perigee/apogee month would be 1/27.3216+2/(365.242*18.6) - 1/27.5545 = 1/(365.242*4.534)
So that the moon's declination wrt to the equator goes in and out of perfect alignment with the ecliptic plane at cycles related to the 18.6 year lunar nodal precession, which is related to the other extreme flooding cycle of 4.53 years (as mentioned upthread, occurring in Bay of Fundy as well as elsewhere). I have to conclude that the extremes at 18.6 and 4.534 years are more likely lunar ecliptic alignments than wrt declination?
I assume some sort of coordinate transformation is needed to get the NASA JPL Horizons output to align with an ecliptic orientation rather than the geocentric equatorial orientation it does now. I think it requires applying a rotation matrix using the obliquity ϵ such as:
x′=x
y′=y⋅cos(ϵ)−z⋅sin(ϵ)
z′=y⋅sin(ϵ)+z⋅cos(ϵ)
