Investigating Orifice Problem: Pipe Head Differences & Theoretical Head
The discussion focuses on calculating the theoretical difference in head pressure before and after an orifice, based on given pipe dimensions and flow rates. The experimental difference in pressure head is noted as 25mm, while the theoretical calculation yields a difference of 9.7mm. The calculations involve determining velocities before and after the orifice using flow rates and cross-sectional areas. Concerns are raised about the theoretical result being significantly lower than the experimental value, suggesting that local and frictional losses may not have been accounted for. The thread seeks clarification on the accuracy of the theoretical calculation and its implications.
matthew_hanco
Orifice problem I've been given a list of quantities
Pipe before orifice head = 255mm
Diameter = 31.75mm
Pipe after orifice head = 230mm
Diameter= 20mm
Time for 10litres to fill in collection tank 67.09seconds
Assuming g= 9.81 and density = 1000
from the experiment difference in pressure head = 25mm
They wanted to know the theorectical.
Calling everything before head 1 and after head 2
u1= Q/ A where Q= 0.149 x 10^-3 m^3/s and A = 0.791x10^-3 m^2
u1 = 0.188
u2= Q/ A where Q= 0.149 x 10^-3 m^3/s and A =0.314x 10^-3 m^2
u2= 0.475
putting into equaton
P1-P2/p x g = u2^2/2g - u1^2/2g where p=density
gives the difference in theoretical head = 9.7mm
Im not sure if that is right as its a third of the experiment, if it is right how can it be because surely the theory should be higher as you don't take into account the local or frictional losses.
Hope someone can help.
Diagram or complete staement of the problem?
The problem was find the theoretical difference in head pressure before and after orifice. Then compare with experimental difference in head pressure. No diagram wasnt given one to begin with. sorry
11K
  • · Replies 25 ·
