White Holes & Eternal Black Holes: Stephen D.H. Hsu
  • Thread starter Thread starter bcrowell
    Holes Paper
bcrowell
Staff Emeritus
Insights Author
White holes and eternal black holes
Stephen D.H. Hsu
http://arxiv.org/abs/1007.2934
I though this was very interesting, and partially cleared up some of the confusion I'd had about this topic in the past. The introductory section is very nontechnical and accessible.
One thing that wasn't very clear to me was whether the entire paper only tells us anything interesting about microscopic black and white holes, or whether it also tells us something useful about macroscopic ones.
He says that white holes explode into radiation. I guess there would have to be some kind of time-scale for this process. But when does the clock start ticking on that time? He doesn't seem to explicitly consider the process of formation of a white hole, so that issue seems muddy to me.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
