Parallelepiped only cutting 4 faces vertically
  • Thread starter Thread starter squenshl
    Cutting
To create a rectangular box from a parallelepiped by cutting only four faces vertically, the initial cut should be made down the middle, perpendicular to the top and bottom. After this, the right half can be repositioned to the left side of the left half, aligning the new vertical outsides. For the remaining cuts, it is suggested to cut the left section and rotate it to place it under the right face, followed by similar adjustments for the front and back sections. This approach indicates that two additional cuts may suffice unless a different parallelepiped configuration is intended. Further clarification on the specific shape may be necessary for tailored guidance.
squenshl
I was just wondering how I can start out with a parallelepiped only cutting 4 faces vertically, at right angles to the edges I cut through & rearrange the pieces so that I can get rectangular box so that the volume is the area of the base times the height. I have done the first cut, a cut vertically down the middle that is perpendicular to the top and bottom then put the right half on the left hand side of the left half, now the new outsides are vertical and the parallel faces are in the middle together. Can someone help me with the 3 remaining cuts and rearranging them to make a rectangular box so the volume of this can be the area of the base times the height.
Mathematics news on Phys.org
If it's all regular, you can cut the left, turn it and place it under the right face. Then do the same with front and back. Seems as if two cuts will be enough. Except you have another parallelepiped in mind, in which case we need more details.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
