momentum
- 111
parallelogram properties
1.>Each diagonal divides it into two congruent triangles.
2.>Diagonals need not bisect angles at the vertices.
I don't understand these two properties.
In property 1:
what does congruent triangles means ? i am not familiar with this term...is this same as "similar triangle" ?
please explain.
In property 2:
it says, diagonal does not bisect vertices. If this is so , that means two halves of the triangle does not have the same area when a diagonal divides the parallelogram...am i correct ?
Or, in other words ,...In mathematical term, if ABCD is the parallelogram and if BD is the diagonal...then Area ABD =! Area BDC ...is this correct ?
In property 1:
please explain.
In property 2:
