Parametrics - intersection and collision
To find the points of intersection and collision between the parametric equations, the user attempts to eliminate parameters and set the equations equal. They derive a complicated equation involving both x and y but struggle with manual calculations and seek assistance. Graphing suggests potential intersection points at (5,3) and (2,10), but the user is uncertain about collisions, as the calculated t values do not match for both equations. A response confirms that (2,10) is indeed an intersection but questions its status as a collision, indicating further exploration is needed. The discussion highlights the challenges in solving parametric equations and the need for clarity on the definitions of intersection versus collision.
Pi Face
x1t= 2-cos(pi*t)
y1t= 3+7sin(pi*t)
x2t= 3t+2
y2t= -(7/15)(3t+1)2 + 157/15
Find points of intersection and collision
above?
Well, to find the intersection I think I need to eliminate the parameters for both equations so I get an equations in terms of x and y, and then set them eqaul to each other.
x=2-3cos(pit)
3cos(pit)=2-x
cos(pit)=(2-x)/3
y=3+7sin(pit)
7sin(pit)=y-3
sin(pit)=(y-3)/7
using the rule cos^2+sin^2=1 and substituting, we get
((y-3)/7)^2 + ((2-x)/3)^2 = 1
I guess we should solve for y here?
Seems a little unwieldy to simplify; is there a trick or something?
Anyways, I used the solve function on my calc and got
y= (7*sqrt(-x^2 + 4x+5) +9) / 3
now on to the other curve
x=3t+2
3t=x-2
t=(x-2)/3
plug the equations for t into the y equation
I really don't know how to deal with this manually. the y2t function is complicated enough by itself, and now i have to replace t with a fraction.
I did however graph the function and i think maybe the answers are t=1 which is (5,3) and t=1/2 which is (2, 10)
not entirely sure.
and then for collision, we set the x functions to be the same?
2-3cos(pit)=3t+2
3cos(pit)=3t
cos(pit)=t
I used a calc and got t= -1, -0.7898, 0.377
can the last two values be represented in fractional from with pi?
now i do the same thing w/ y functions
3+7sin(pit)= -(7/15)(3t+1)2 + 157/15
do i have to pretty much use a calculator for this?
anyways, i got t=-1.208, 0.307, 1, 1.52
none of the t values are the same.
in desperate need of help please >.>
anyone? =(
even partial help would be appreciated
Ok, I'll give you partial help. You probably meant "x1t= 2-3*cos(pi*t)" in your problem statement, right? Since that's what you used in trying to solve it. I think you are taking the correct approach. (2,10) is an intersection. I don't think it's a collision, can you tell me why? There's another real intersection as well, which I'm pretty sure is not a collision. You are pretty good at this, just keep working on it and I'll check in tomorrow. Sorry, it's really late here.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
