Partial differentiation question rocket trajectory
The discussion revolves around a problem related to partial differentiation in the context of rocket trajectory, specifically focusing on differentiating expressions involving the coordinates x(t), y(t), and z(t) as functions of time t.
  • Participants discuss differentiating the expression for the distance involving the square root of the sum of squares of the coordinates. There are attempts to apply the chain rule and questions about how to handle the variable t in the differentiation process.
Several participants have shared their attempts at differentiation and expressed uncertainty about the approach. Guidance has been offered regarding the application of the chain rule and the nature of the resulting expressions. There is an ongoing exploration of how to express the results in terms of constants and the role of the variable t.
Some participants note the expectation of partial differentiation in the problem, raising questions about the relevance of the approach being discussed. There is also mention of homework constraints regarding the format of submissions.
AwfulPhysicist
The problem and my attempt are attached
Chain rule for partial differentiation perhaps
And basic algebra
I'm unsure of how to approach this but I differentiated all the expression at the top.
Can you try and differentiate the square root [itex]\sqrt{x(t)^2 + y(t)^2 + z(t)^2}[/itex] to [itex]x(t)^2 + y(t)^2 + z(t)^2[/itex] first and work from there?
No. The three coordinate functions x(t), y(t), and z(t) are functions of t alone, and you're asked to find dr/dt.
Calculate x2 + y2 + z2, then take the square root, then differentiate with respect to t.
And basic algebra
In your work it looks like you're trying to integrate both sides. Try to resist that urge.
Calculate x2 + y2 + z2, then take the square root, then differentiate with respect to t.In your work it looks like you're trying to integrate both sides. Try to resist that urge.
hi
How can I differentiate this?! Is it just
(Terms)^1/2 and differentiate using chain rule?
Also how would I be able to get rid of the t's at the end?
I've differentiated it using the chain rule, looks horrible
But now I need to get rid of the t's
hi
Yes.
You don't get rid of them.
Please post your work here in the form, not as an image, and especially not as an image that is turned on its side.
Yeah sorry, sure.
hi
Yes, it is just (Terms)1/2 and differentiate using chain rule .
You don't get rid of the time. The resulting expression for speed is a function of time, t .
[itex]\frac{dr}{dt}[/itex] is a function of [itex]t[/itex] so you don't want to get rid of the t's. The t's might cancel out in some problems, but, in general, we expect a function of t to have t's in it.
  • · Replies 18 ·
  • · Replies 17 ·
