Partial Fraction Expansion with repeated & complex roots
The discussion focuses on the methods for finding coefficients in partial fraction expansions involving repeated and complex roots. The examples provided include the expression 4/s(s+1)^2, where coefficients A, B, and C are determined using algebraic manipulation, yielding A=4, B=-4, and C=-4. For complex roots, the expression 2/s(s^2+s+1) is introduced, but the participants emphasize that the cover-up method is ineffective for polynomials of degree higher than 2. The conversation highlights the importance of correctly splitting equations and determining coefficients through systematic substitution.
  • Understanding of partial fraction decomposition
  • Familiarity with algebraic manipulation techniques
  • Knowledge of complex numbers and quadratic equations
  • Experience with polynomial expressions and their coefficients
  • Study the method of partial fraction decomposition for repeated roots
  • Learn how to apply the quadratic formula to find complex roots
  • Explore the systematic substitution technique for determining coefficients
  • Research common pitfalls in partial fraction expansions involving higher-degree polynomials
Students and professionals in mathematics, engineering, or physics who are working with differential equations and require a solid understanding of partial fraction expansions, particularly involving repeated and complex roots.
CremeBrulee
I am having trouble to find a straight forward method for finding coefficients using partial fraction expansion with repeated or complex roots. My study notes arent too clear so I am finding the differentiation method hard to follow for repeated roots. As for complex roots I can find the roots using quadratic formula but then not sure how to find the coefficients? Are there any simple methods out there that can used used for these types of equations?Any help would be appriciated?
Repeated roots
4/s(s+1)^2
4/s(s+1)^2=k1/s + k2/s+1 + k3/(s+1)^2
k1=4; k3=-4 (Using cover up method)
k2=??
Complex roots
2/s(s^2+s+1)
(s^2+s+1) = -1/2 +/- j sqrt(3/2)
That "cover-up" method doesn't work with any polynomial with a degree higher than 2.
You'll have to solve k1/s + k2/s+1 + k3/(s+1)^2 the normal way.
Repeated roots
4/s(s+1)^2
k2=??
Complex roots
2/s(s^2+s+1)
CremeBrulee,
I do not know what exactly is meant by the cover-up method, but these two examples are very straightforward. You start very well, but than you seem to be lost. I will explain the first one, the second one you need to do yourself. (I wrote the first one down on a piece of paper in about 20 seconds... the typing is a way bit longer...)
OK, you have:
\frac{4}{s(s+1)^2}=\frac{A}{s}+\frac{B}{s+1}+\frac{C}{(s+1)^2}
Or:
A(s+1)^2+Bs(s+1)+Cs=4
As^2+2As+A+Bs^2+Bs+Cs=4
(A+B)s^2+(2A+B+C)s+A=4
setting the LHS and the RHS equal to each other in the different s-terms we have already:
A=4
A+B=0
thus:
B=-4
2A+B+C=0
thus:
C=-4
the equation becomes now:
\frac{4}{s(s+1)^2}=\frac{4}{s}+\frac{-4}{s+1}+\frac{-4}{(s+1)^2}
Can you do the second one in the same manner? Do not try to find the roots of the quadratic that is not necessary. Write down the first step and in case you are not sure how to split it up, come back and ask.
coomast
As Coomast said, you can quickly arrive at
You can simplify a lot by taking s= -1:
A(0)^2+ B(-1)(0)+ C(-1)= 4
so that you get C= -4.
You can simplify a lot by taking s= 0:
A(0+1)^2+ B(0)(0+1)+ C(0)= 4
so that you get A= 4.
Finally, just choose some third number: s= 1 will do.
A(1+1)^2+ B(1)(1+1)+ C(1)= 4
4A+ 2B+ C= 4
And, since A= 4 and C= -4,
16+ 2B- 4= 4
so that
2B= -8
and B= -2.
Thanks for the replies everyone. This process seems really straightforward but I'm still having trouble...grrr.
I do have a couple of questions:
How do I determine how to correctly split up the equation ie what s term goes next to each coefficient A, B , C, etc? I tried the second question but wasn't sure how to split it? What is the convention when splitting both repeated and complex roots?
The way I understood the explanation is that the s terms in brackets equal zero and the singular A equals 4.
Then using the value found for A it can be plugged into the remaining coeffs in the s terms in brackets that equal zero to find remaining coefficients. Are the s terms in brackets always zero?
A+B=0 ; 2A+B+C=0
But what happens if there isn't a singular coefficient or say if there were two repeated roots and so two singular values? Does this process still work?
I also tried the method using Hallsof Ivy suggested (s=0, s=1, s=-1) but I found B=-8? However, I know the answer is A=4, B=-4 & C=-4 from my textbook, so we were both incorrect?
37K
