I Particle in a box, boundary co-ordinate change
I_laff
If you have a particle in a 1-d box with a finite potential when ##0 < x < L ## and an infinite potential outside this region, then the normalised wavefunction used to describe said particle is ## \psi (x) = \sqrt{\frac{2}{L}}\sin(\frac{n\pi x}{L})##.
However, if you had say instead a finite potential when ##\frac{-L}{2} < x < \frac{L}{2}## and an infinite potential outside this region, then wouldn't the wavefunction now change?
Actually would the wavefunction be ##\sqrt{\frac{2}{L}}\cos(\frac{n\pi x}{L})## instead?
Yes, it would.
Assuming you've done the math right (I haven't checked), yes. However, this change has no physical significance because the problem is still the same square well of width ##L##. It's analogous to what happens if we decide to draw the prime meridian through something other than the Greenwich observatory - everything that is a function of longitude changes, but the surface of the Earth does not.
You can set the problem up either way, and in practice you will pick whichever way makes the algebra easiest for you.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
