Particle in a Box, normalizing wave function
EbolaPox
Question from textbook (Modern Physics, Thornton and Rex, question 54 Chapter 5):
"Write down the normalized wave functions for the first three energy levels of a particle of mass m in a one dimensional box of width L. Assume there are equal probabilities of being in each state."
I know how to normalize a wave function, I'm just not too sure exactly how I do so for three different energy levels.
My work and ideas:
Previously in the chapter, they stated \Psi = A sin(kx - \omega t). Next, I saw E_n = \frac{ \hbar ^2 n^2}{8ml^2}. I know for the wave function to be normalized, I need 1 = \int_{0}^{l} |\psi|^2 dx, but I'm not too sure how to proceed or really use any of this. Do they want me to somehow algebraically manipulate my kx-wt to get an expression for energy inside? Perhaps I'm just confused as of to what they want me to do. Any hints or pointers in the right direction would be great. Thank you.
What really annoys me is I've done the problems in the next chapter and some problems in Griffiths intro to QM book, but this problem which seems so simple is the only one that has a solution that has evaded me. Thanks again for any help.
Well, you've got it wrong.
What is \Psi? Usually* this is the solution to \mathcal{H} \Psi = E_n \Psi. So it shouldn't be time dependant. For a particle in a box you should solve just note the boundary conditions - zero at the ends of the box, so \Psi_n \propto \sin \left( \frac{n\pi x }{L} \right)
To normalize, you should do what you said that should be done - write 1 = A^2 \int_{0}^{l} |\psi|^2 dx where \psiis what we found before, and find A. So \Psi=A\psi.
The answer is that the normalization factor is always √2/√L
Sometimes \Psi is said to be the solution to the time dependant Schrödinger Equation, the difference for your problem is just a global phase.
Ah! Thank you very much. That makes sense. I was just wondering if I could write \Psi in that form, but was worried that I had to have a time dependence in there.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
