Particle in a Box situations
In summary, Schroedinger's equation, in any number of dimensions, gives not only the wave-function of a particle, but also the possible values for the system's energy, known as the Hamiltonian spectrum. The concept of "boundedness" in quantum systems is different from that of physical systems, and is defined as the tendency of the wave-function to approach zero in the asymptotic limit. This can be seen in examples such as the Harmonic Oscillator and the Hydrogen atom.
FUNKER
121
does shrodingers one dimensional equation, if solved, give you the wave function (i.e. the displacement) of a particle ?
If so, then how can this be used in a one dimensional situation since displacement is in 2 dim.?
These questions arise from Particle in a Box situations.
you use 1-D shrondinger eq in 1D problem,which displacement should be in 1d. if you want to do a 2D problem, you should use a 2D Shrondinger eq... hope this answer your question
it has helped thanks
you are welcome
Schroedinger's equation,in any number of dimensions,does give not only the (generally time-dependent) wave-function,but also the Hamiltonian's spectrum,which are the only possible values for the system's energy.
I don't know what u mean by "displacement",however... :confused: Could u be a little more specific,and what kind of Box are u talking about??1D,2D,3D?
Daniel.
im talking bout displacement, and its a 1 d box. i said if you sovle the equation you get a wave function. please read above. what is the hamiltonian spectrum
Solutions of the spactral equation for the Hamilton operator
[tex] \hat{H}|\psi\rangle = E|\psi\rangle [/tex]
,which are in fact the only possible values of the energy the system can take.
Daniel.
PS.U know that "displacement" is entirely probabilistic,okay?
yes I do know that it is but hey thanks for your help. Just to recap the hamiltonian spectrum is just all possible values for a particle in a bound system?
All possible values for the energy of the Q system.
What do u mean by bounded??
Daniel.
i.e. an electrons potential energy is negative whilst "belonging" to an atom
Well,according to QM,the electrons in atoms can be found anywhere...So u can't call an atom as being "bounded".While the potential energy is basically unbounded in the origin.The sign is not important...
Daniel.
Isn't the definition of bounded the emergence of discrete energy levels? Or is a better notion the limit of the wavefunction as position goes to infinity?
I would think the latter is more rigorous, but it is not entirely obvious to me whether the discrete energy levels are enough to define whether the system is bound. Can anyone think of a counter-example for the quantized energy levels of a non-bound system? How would you define "bounded" if an atom is not one?
Bounded quantum states...It's something totally different than bounded physical systems... :wink:
Norman said:
Entirely obvious to me whether the discrete energy levels are enough to define whether the system is bound.
I told u...REAL quantum systems are not "bounded".How would you define such a "boundness"??
Hydrogen atom,bound states?LHO ?
What do you mean "atom is not one"??You mean,if the NUMBER of atoms is larger than one??Bounded quantum states of multiparticle quantum systems??
Maybe the Hamiltonian of the system should have a discrete spectrum...?? :rolleyes:
Daniel.
Ok, so which are we talking about here and what is the difference? If you mean the difference between a Harmonic Oscillator (a bounded quantum state- if I understand what you are saying) and say a Lithium atom (a real system), then I think I understand what you are saying, if not would you please elaborate?
Daniel.
I think you are misunderstanding me. Or I am misunderstanding you. You answered my exact question with the same question. Are we defining "boundedness" as the emergence of a discrete spectrum from the Hamiltonian or should we look at how the wavefunction behaves at infinity? I am not challenging you, so please don't become defensive, I am only trying to understand.
Cheers,
Norm
I hope we're talking about the boundness of quantum states... :rolleyes: I said that the only way to have "bounded systems" in QM is to have infinite potential barriers.Or that thing is unattainable in reality...
Yes,u got the picture... :smile:
Fot the quantum states we do...Bounded quantum states are eigenstates of the Hamiltonian...
By a simple extrapolation of the first principle,we would say:bounded quantum states<=>quantum states on which the wavefunction tend to zero in the asymptotic limit (coordinate representation).
Daniel.
Daniel.
Ah... very good point. I must remember to appeal to the principles of QM.
Thanks a lot for the enlightenment and the quick reply.
Cheers,
Norm
What is a "Particle in a Box" situation?
A "Particle in a Box" situation is a theoretical model used in quantum mechanics to illustrate the behavior of a particle confined within a finite space. It assumes that the particle is free to move within the space, but cannot escape its boundaries.
What is the significance of studying "Particle in a Box" situations?
Studying "Particle in a Box" situations helps us understand the principles of quantum mechanics and the behavior of particles at the atomic and subatomic level. It also has practical applications in fields such as nanotechnology and materials science.
What are the assumptions made in a "Particle in a Box" situation?
The main assumptions are that the walls of the box are infinitely high, the particle is confined to the box and cannot escape, and the potential energy of the particle is zero within the box and infinite outside of it.
What is the Schrödinger equation and how is it used in "Particle in a Box" situations?
The Schrödinger equation is a fundamental equation in quantum mechanics that describes the time evolution of a system. In a "Particle in a Box" situation, it is used to calculate the allowed energy levels and wave functions of the particle within the box.
Can a "Particle in a Box" situation be applied to real-world scenarios?
While the model itself is idealized and may not directly correspond to real-world situations, the principles and concepts learned from studying it can be applied to understand and predict the behavior of particles in various systems, such as atoms and molecules.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
