genloz
- 72
- 1
Why do two particles have to be antiparticles of each other to mix?
No. They usually have to be close in mass.genloz said:Why do two particles have to be antiparticles of each other to mix?
clem said:No. They usually have to be close in mass.
It is now believed that different types of neutrino mix.
genloz said:Thanks for all the comments! I have a question that states:
"For two particles, A and B, to mix, A and B have to be anti particles of one another. Why then does a neutron not mix with an antineutron?"...
I'm not sure exactly what is meant by mix but just wanted to understand why the particles have to be antiparticles of each other in the first place before tackling the question...
if you click in the number, you come to the actual dataMean n n-oscillation time >8.6 × 10 7 s , CL=90%
If your university has a good bunch of paid e-journals, you can even click in the links to go to the papers.A test of ΔB=2 baryon number nonconservation. MOHAPATRA 1980 and MOHAPATRA 1989 discuss the theoretical motivations for looking for n n oscillations. DOVER 1983 and DOVER 1985 give phenomenological analyses.
arivero said:The question is right if you add context; it is referring not to any abstract elementary particle mixing but to mixing in the sense of Kaon mixing or, as pointed above, D or B mixings. In the case of Kaon, it is K and Kbar, this is down-antistrange and antidown-strange, which obviously are antiparticles one of another. I'd not say it is a prerrequisite: what you need is to have same charges and nearby masses, and obviously it works here.
In general, particles mix to produce eigenstates of the symmetry-breaking-part of the Hamiltonian.
We know that isospin and strangness conservation are violated by the weak interaction Hamiltonian. Thus there is no reason why K^{0} and \bar{K}^{0} should not be able to transform into each other through the weak interaction. This is in fact possible via the intermediate 2-pion state
K^{0} \rightarrow (\pi^{-} + \pi^{+}) \rightarrow \bar{K}^{0}
Thus, one can say that Kions mix to produce the weak-hamiltoian (short & long) eigenstates
K^{0}_{L} = 2^{-1/2}( K^{0} + \bar{K}^{0})
K^{0}_{S} = 2^{-1/2}( K^{0} - \bar{K}^{0})
So the question stands: why the mixing does not apply to neutron?
Not realy, It seems the baryon number is an absolutely conserved quantity, therefore a neutron can never transform into an antineutron, i.e., mixing can never occur.
regards
sam
arivero said:.
Next question could be: why Barionic number, or at least B-L, is a preserved quantity in the standard model?
The symmetry group of SM is SU(3)XSU(2)XU(1), The baryon number (like the electric charge) is the Noether number corresponding to the exact (nubroken) global U(1) part.
sam
samalkhaiat said:The symmetry group of SM is SU(3)XSU(2)XU(1), The baryon number (like the electric charge) is the Noether number corresponding to the exact (nubroken) global U(1) part.
sam
samalkhaiat said:arivero said:.
I would like to learn this physics stuff. Please, list here all the easily accessible and valuable particle physics articles you can find/remember. There are some very good ones that are pedagogical and easy to approach.
I do not mean popular particle physics text. I mean publications and learning materials for undergraduate and graduate students in physics. For example, article that demonstrates group theory intuitively for particle physicist...
PS. There are lots of articles in arxiv.org, but it is not very easy to find the best ones.
Thanks...
mormonator_rm said:You are right to say that the electric charges must be equal for mixing to occur. However, the masses do not have to be close for mixing to occur; the mixing will have the same matrix element either way, but the effect of the mixing will appear much weaker as the pure-state masses are further apart.
arivero said:Next question could be: why Barionic number, or at least B-L, is a preserved quantity in the standard model?
Urvabara said:Hi!
Thanks...
samalkhaiat said:I would like to learn this physics stuff. Please, list here all the easily accessible and valuable particle physics articles you can find/remember. There are some very good ones that are pedagogical and easy to approach.
sam
blechman said:You write down all the allowed operators by the gauge symmetries, and you stop after dimension 4 (to keep things renormalizable). Then you find that you have this accidental symmetry. You expect higher-dimension operators to violate this symmetry, and they do. Extensions of the renormalizable part of the SM have dimension 5 and 6 operators that permit proton decay and other B and L violating processes.
arivero said:What I do not get is the dimensionality of the operator. For instance, such disintegration could be mediated by a gauge "diquark boson" having colour in 3* and charge +1/3: in a first step two quarks u and d collide to create this boson, and then it is absorbed by the extant u quark, which mutates into a positron. But what is the dimension of this boson operator?
arivero said:Another point is that this operator had changed the number of particles, or if you prefer had converted a particle into an antiparticle. That seems to violate T, doesn't it? Is it possible to keep B-L and violate B without violate T? At a first glance, it seems it isn't.
blechman said:Sorry, I just noticed this second question. You haven't violated fermion number, so I'm not sure why T must be violated.
Changing a quark to an antiquark doesn't violate T, since a quark moving forward in time is the same as an antiquark moving backward in time (T is anti-unitary).
blechman said:But when you break the GUT symmetry and integrate out all of the heavy extra gauge bosons, you end up with operators like the one I wrote down, with M\sim M_{\rm GUT}.
Does that help?
arivero said:I was thinking the whole process to disintegrate the proton: I start with three quarks, then I obtain an antiquark and two quarks (and the gauge boson of a beyond SM group), them an antiquark, quark and a lepton (because the gauge boson is absorbed by the extant quark) and finally a single lepton. Pretty sure I have three fermions at the start and only one at the end.
blechman said:What, precisely, is this "gauge diquark boson"? There's no such object living in the standard model. The canonical example of proton decay in the standard model comes from the dimension-6 operator:
<br /> \frac{c}{M^2}\overline{Q}\gamma^\mu Q\overline{Q}\gamma_\mu L<br />
where Q, L are the quark and lepton weak-isospin doublets; c is an order one constant and M is the scale of new physics (the cutoff). This operator would destroy a u and d quark, and create a lepton and an antiquark, mediating the decay p --> pi+e. This operator does not violate any gauge symmetries, and therefore it is allowed; it violates B and L, but not B-L. But it is a 4-quark operator, and is therefore dimension 6 (each fermion has dimension 3/2 in 4D spacetime).
The example you gave would involve the existence of a new gauge symmetry. This is the kind of things that happens in GUT models. But when you break the GUT symmetry and integrate out all of the heavy extra gauge bosons, you end up with operators like the one I wrote down, with M\sim M_{\rm GUT}.
Does that help?
blechman said:Cute. But the nice thing about an operator analysis (what I was doing) is that it is model-independent (Rishon or Chiral quarks or whatever). Such an operator exists since it can't be forbidden by gauge symmetries, and you can get very far from that. However, the best you can do typically is order-of-magnitude. You say the difference between SM and R is a factor of 2 - such precision is far greater than what I was going for: I'm looking for factors of 10!
mormonator_rm said:I should try to learn more about operator analysis. I am trying to think where I have seen it all done before, maybe one of my old textbooks would shed some light on it.
blechman said:It's a VERY powerful tool, used all over physics. Most QFT texts discuss it, but you can probably get an even better explanation from summer-school lectures. Look around for TASI or Les Houches lectures with the title "Effective Field Theory" - there are a whole lot of them out there. Some of my favorites are those by David B. Kaplan; Ira Rothstein; Aneesh Manohar; Howard Georgi; Cliff Burgess; this list goes on and on! Each of these reviews approaches the problem from the point of view of the author's specific research, so you can check out several of them to see different applications.
Have fun!
nrqed said:It's neat to see that you are working on this!
I did my PhD with Peter Lepage on applications of EFTs to nonrelativistic bound states and my postdoc with Burgess. I unfortunately got discouraged with the job market and left research for teaching, hoping I would do research on the side but things got in the wayNow I am trying to get back doing research.
blechman said:The canonical example of proton decay in the standard model comes from the dimension-6 operator:
Where, in the SM Lagrangian, do you find such coupling? Or, which part of the Lagrangian produces the "current" \overline{Q} \gamma_{\mu} L in your operator?
In order to have such current, the Lagrangian must contain a kitetic term of the form
i \overline{Q} \gamma_{\mu} \partial^{\mu}L
But, the SM Lagrangian does not have such kinetic term! Therefore, your operator (quoted above) does not live in the SM, i.e., you can not speak about proton decay in the SM.
The same conclusion can be reached if we study the representation of the symmetry group of the SM:
The fields in ANY Noether current must belong to the same representation (multiplet). In the SM, quarks and leptons do not occupy the same multiplet, i.e., under the action of
SU(2)XU(1), Q and L do not transform into each other. Therefore, the gauge group
SU(2)XU(1) does not allow you to write the object \overline{Q}\gamma_{\mu}L. Indeed, doublets such as (d , e)^{t} or (u , \nu)^{t} do not belong to the representation of SU(2)XU(1). This is because the product group
SU(2)XU(1) requiers all members of an SU(2) boublet to have the same weak hypercharge [the generator of U(1)];
Since Y(Q) \neq Y(L), SU(2)-doublets must be of the form (Q_{1},Q_{2})^{t}, (L_{1},L_{2})^{t} with Y(Q_{1}) = Y(Q_{2}) and Y(L_{1}) = Y(L_{2}), a doublets like (Q_{i},L_{j})^{t} do not transform correctly under SU(2)XU(1). So, within the symmetry group of the SM, your operator
( \overline{Q} \gamma^{\mu} Q)( \overline{Q} \gamma_{\mu} L)
is not allowed, i.e., the mathematical structure of the SM has no room for proton decay.
However, your current and operator are allowed beyond the SM, i.e., when the gauge group is larger than SU(3)XSU(2)XU(1) [say SU(5)]. Indeed, in this case, quarks and leptons appear in the same representation ([5],[5*] and [10]) allowing us to speak about proton decay
regards
sam
With a caveat: not to let EFT become an ideology, or you can start claiming that after all every QFT is an effective one and than any accelerator experiment is not fundamental and that renormalization is not a guide for any fundamental thing at this level and then to go to GUT scale, and even then to Planck scale for fundamental truth. A sad process to follow.blechman said:. EFT teaches you how to think! Once you know that, the sky's the
samalkhaiat said:blechman said:Therefore, your operator (quoted above) does not live in the SM, i.e., you can not speak about proton decay in the SM.
The same conclusion can be reached if we study the representation of the symmetry group of the SM...
(1) In the formal definition of the **perturbative** SM which only keeps the renormalizable operators (with dimension <=4) you are right - there is technically no proton decay. The operator cannot be generated since there's no current, as you say.
But what you are forgetting is that B and L are ANOMALOUS! Therefore, there are instanton effects that can generate such an operator as the one I wrote down. Of course, such operators come with coefficients that are exponentially small, so there is no contradiction with experiment. However, the operator is generated, although not through perturbation theory (no feynman graphs)!
(2) It is generally accepted that the SM is not the end of physics - if nothing else, something must happen at the Planck scale to incorporate gravity into the picture. Since B and L are only accidental symmetries of the SM, there is absolutely no reason to assume that they will continue to hold past dimension-4 operators. Since the operator I wrote down is allowed by all the gauge symmetries, it must generally be there, unless there's an additional symmetry imposed beyond the SM. Indeed, in most naive extensions of the SM (SUSY, GUT, technicolor, etc) such operators are in fact generated after integrating out the new physics.
So the operator is there, formal definition of the perturbative SM aside!
Well, historically, we lived under the rule of a nonrenormalizeble operator, Fermi quartic coupling, since the mid fifties under the late sixties, and only in the early seventies a right renormalizable theory was found (and renormalizability proved by veltman and 't hoof. I think that the doctrine of Effective QFT was already strong in the late seventies, so the historicity of the blessing of renormalizability can be a myth.blechman said:Historically, we thought that renormalizability was some God-like quality of good QFTs. We now understand that this is not so: there is nothing special about renormalizable operators.
