Particle moves in one dimension given potential funct find maximum x
The discussion focuses on solving a one-dimensional particle motion problem under a potential function. The correct formulation of the force is emphasized as being opposite to the direction of velocity, leading to the equation du/dx = -f(x). Conservation of energy is applied to derive the velocity and displacement equations, ultimately showing that the particle exhibits sinusoidal oscillation. The integration process is clarified, correcting misconceptions about treating x as a constant. The final results confirm the periodic nature of the motion, with the period derived from both energy conservation and differential equations.
oddjobmj
Please delete this post.
Look..It's easy..
du/dx=f(x)..(this is where you are making mistake).The correct equation is du/dx= -f(x)
so f(x)= -2cx(This force is opposite to the direction of velocity of particle.i.e.the force is in negative x-direction..
Now do the process again and you will easily reach the answer..
Likes 1 person
You do not need to differentiate the potential energy and use Newton's second law.
You already have conservation of energy: ## \frac {mv^2} {2} + cx^2 = \frac {mv_0^2} {2} ##, thus ## v = \sqrt { v_0^2 - 2 \frac c m x^2} ##, or ## \frac {dx} {dt} = \sqrt { v_0^2 - 2 \frac c m x^2} ##.
Can you solve this?
If you insist on using Newton's second law, then I should say that this step of yours: ## \int 2cxdt = \int m dv \Rightarrow \frac {2cxt} m = v + \text{constant} ## is already wrong, and not really because of the missing minus sign, but because ##x## is a function of time, no a constant, so its integral is not ##xt##.
Likes 1 person
So you have $$
\int_0^{x_m} \frac {dx} {\sqrt{v_0^2 - 2 \frac c m x^2} } = \int dt
\Rightarrow
\int_0^{x_m} \frac {dx} {\sqrt{1 - (ax)^2} } = v_0 \int dt
$$ where $$
a^2 = \frac {2c} {mv_0^2}
$$ Then $$
\frac a a \int_0^{x_m} \frac {dx} {\sqrt{1 - (ax)^2} } = \frac 1 a \int_0^{ax_m} \frac {d(ax)} {\sqrt{1 - (ax)^2} } = \frac 1 a (\arcsin ax_m - \arcsin 0) = \frac 1 a \arcsin ax_m = v_0 t
$$ Now ## x_m = \sqrt { \frac {mv_0^2} {2c} } = a^{-1} ##, so ##\frac 1 a \frac {\pi} 2 = v_0 t ## giving $$ t = \sqrt {\frac m {2c} } \frac {\pi} 2 $$ Also of note is that you can find ##x## as a function of ##t##: $$ x = a^{-1} \sin av_0t $$ which is a sinusoidal oscillation with period ## \frac {2 \pi} {av_0} = 2 \pi \sqrt { \frac {m} {2c}} ##. Clearly the time it takes from max velocity to max displacement is one quarter of the period, which is consistent with the previous result.
If you have studied linear differential equations, you could also observe that Newton's second law gives $$ \frac {d^2 x} {dt^2} + \frac {2 c} {m} x = 0 $$ which is a second-degree linear diff. eq., whose general solution is $$ x = A \sin (\sqrt{\frac {2c} m}t + \alpha) $$ which is again periodical with the same period, of course.
I greatly appreciate your help. Your solution is a work of art. I will plug in some hypothetical numbers to make sure our solutions are equivalent (unless you have already checked this). I need to write a solution in my own way and I simply would not legitimately be able to reproduce your solution on my own. Although I have saved this solution and will use it to improve with time.
Thanks again!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
