Particles with electric charges visible to the human eye?
The discussion centers around the visibility of charged particles to the human eye, particularly under LED light, and their interaction with magnetism. Participants explore definitions of "particles" and the conditions under which they can be seen, as well as the implications of size and charge.
  • Some participants inquire whether any charged particles can be seen with the naked eye under specific lighting conditions.
  • One participant mentions the visibility of charged styrofoam particles, questioning if they fit the definition of "particles."
  • Another participant suggests that carbon gas particles could be relevant to the discussion.
  • There are claims that larger clumps of particles can be seen with microscopes, but individual particles remain a point of contention.
  • Several participants emphasize the need for a clear definition of "particle," noting that traditional particles like electrons and protons are too small to be seen by the naked eye.
  • One participant describes observing particles in a condensation window, asserting they are repelled by magnets, while others challenge the clarity of this observation.
  • Another participant argues that the ability to see something with the naked eye is more about size than charge or magnetic properties.
  • There are references to videos illustrating particle behavior, but the relevance of these to the original question is debated.
  • One participant mentions studying the effects of a substance (C3H8O2 PG) and its charge, expressing uncertainty about their findings.
Participants do not reach a consensus on the definition of "particles" or the visibility of charged particles. Multiple competing views remain regarding what constitutes a particle and whether any can be seen with the naked eye.
Participants express varying interpretations of what qualifies as a "particle," leading to ambiguity in the discussion. The relationship between visibility, size, charge, and magnetic properties is also not clearly resolved.
Joe Hagner
Are there any particles known in the Physics world with an either positive or negative charge that can be viewed by the human eye under LED light illumination and have an attraction/repulsion to magnetism?
Define by what you mean by "particle". I can charge tiny styrofoam "particles" and I can see this with my naked eyes. But does this count? Without any elaboration on your definition, I don't know.
Zz.
For instance carbon gas particles
Sure you can see big clumps of particles with a microscope or even individual particles with electron microscope.
Pretty sure he's referring to individual particles and naked eye
to which the answer would be noDave
Thanks Dave
Joe Hagner said:
Thanks Dave
If you look closely at the condensation window you can faintly see what I am seeing, these were placed inside the sealed bottle last night around 10 pm, out in the open they are repelled by N42 neodymium magnets, just curious if anyone has seen anything like this before and I have some more pictures and will be getting some higher quality pictures with different spectrums
I'm not exactly sure what you're getting at here. Are you saying that these are images of "individual particles"? I can see dust particles in the air whenever the light shines just right.
Look, I still think that your idea of "individual particle" is very vague (in fact, you've offered none other than a puzzling example even after I asked).
Here are the facts: well-known "particles", such as electrons, protons, etc... are WAY to small to be seen by our naked eyes. Period. The light that can be used in a similar fashion as what we ordinarily see have wavelengths that are just orders of magnitude too short to be within the visible range (they are also too energetic to be safely viewed with our eyes).
So unless you have a definitive length scale that you consider to be within your definition of "individual particles", the answer you'll get can range from "NO" to "YES", because your definition is fluid and appears to have no clear boundaries.
Zz,.
agree with Zz
Joe, you need to define YOUR definition of particles
As Zz indicated, to a physicist, particles are atoms and sub-atomic particles that make up atoms
your pic shows water droplets they are huge in comparison and easily distinguishable to the naked eye and definitely don't fall into the
realm of what are termed particles
Dave
I took a video to try and better illustrate what I am seeing, just thought it was fascinating the wave and particle action. The video was taken in a room with no ventilation.
I appears that you have zero intention in addressing the issue that I had brought up, which makes this a one way conversation that I'm on longer interested in participating.
My point about dust particles still stand.
Zz.
These are C3H8O2 PG, atomised, not dust, and to my knowledge dust does not react to magnetism
This has nothing to do with magnetism, or charge particles. It has everything to do with SIZE and the definition of "particle" in your original question. To SEE something with your naked eyes does NOT require it to react with magnetism, or have a charge! It has everything to do with how that particle can be distinguished using light in the visible spectrum!
This "size" of a "particle" is what you have failed to define, and what is causing your question to be ambiguous.
Zz.
At what point in the video do you switch on the magnetic field? I couldn't see any obvious reaction.
I will post another video, with the N42 magnet, that was just the particles
He's been asked four times and for some inexplicable reason refuses to provide one. What is with all these questions where the OP pushes to keep the question vague?
I'm going to give up on this thread and move on :rolleyes:
I'm studying the effects PG after it has been ran through upward spiral coil at 40A .5 Ohm, from what I see it has an charge, I'm sorry I am a beginner to all of this, but here is another video you might have much more insight than me on , I'm sorry for the misclassification or naked eye at the beginning.
Closed pending moderation.
  • · Replies 16 ·
