Particular Values of Gamma Function
The discussion centers on the value of the gamma function at 1/2, specifically why gamma(1/2) equals the square root of pi. It highlights the relationship between the gamma function and Gaussian integrals, suggesting that substituting variables can simplify the evaluation. Participants mention that while calculators approximate this value, there are rigorous mathematical methods to derive it, including using polar coordinates and properties of integrals. The conversation also touches on evaluating the gamma function for other inputs, noting that sophisticated numerical methods exist for this purpose. Understanding these relationships clarifies the connection between the gamma function and pi.
GreenPrint
Hi,
I would like to know why is it that
gamma(1/2) = squareroot(pi)
The other values as well. I don't see why out of all values that the gamma function converges to operations of pi of all things. Is there some kind of relationship to the gamma function and the trigonometric function. I don't see how else one would know that it converges exactly to the square root of pi... One could plug it into a calculator and would get that it's about the square root pi due to the fact that the calculator would round off to so many digits but how does one know it's' exactly the square root of pi? There has to be some other way to know this as I don't see how else this can be known.
Thanks.
Assuming you are using \Gamma(z) = \int t^{z-1} e^{-t} \, dt you can substitute x = \sqrt{t} to reduce \Gamma(\tfrac12) to a Gaussian integral.
GreenPrint said:
Hi,
Thanks.
$$\Gamma(x) =\int_0^\infty t^{x-1}e^{-t}\, dt$$ so$$
\Gamma(\frac 1 2) =\int_0^\infty t^{-\frac 1 2}e^{-t}\, dt$$Let ##t = u^2,\, dt=2udu##:$$
=2\int_0^\infty e^{-u^2}\, du$$Are you familiar with how to evaluate that integral?
[Edit] Apparently CompuChip types faster than I do.
Yeah, well, I had less \LaTeX code to type so it's not really fair.
I do not know how to evaluate those integrals. I however was able to look up the definition of the error function and got the square root of pi.
How then do you evaluate the gamma function for any given input x? I'm assuming you have to get it into a form of the error function one way or the other but I can't seem to figure it out.
thanks for all of your help.
For most values of x the error function has nothing to do with the problem. People have developed sophisticated numerical methods to compute ##\Gamma(x)## for general given values of x.
Yes, if you want to integrate exp(-x²) over a finite interval you will need the error function. But if you are interested in
\int_{-\infty}^\infty e^{-x^2} \, dx = \sqrt{\pi},
that result can be proven without defining erf (see e.g. Wikipedia). The trick you need is to square the integral and switch to polar coordinates, once you have seen that proof the occurrence of pi is hopefully no longer a mystery either.
For some other values can calculate the particular value by noting that \Gamma(z + 1) = z \Gamma(z) (proof by partial integration), which immediately gives you, for example, that \Gamma(\tfrac32) = \tfrac12 \sqrt{\pi} as well as \Gamma(n + 1) = n! (by induction and performing the trivial integral \Gamma(1) = \int_0^\infty e^{-t} \, dt = 1).
