Partition function of a classical spring
The discussion focuses on calculating the partition function of a classical spring, specifically addressing the energy expression, which is (1/2)kx^2 for a spring under constant tension. There is confusion regarding whether to include kinetic energy in the calculation, but it is clarified that for a stationary spring, the kinetic term is zero. The relationship between force and elongation is confirmed to be linear, consistent with Hooke's Law. The clarification emphasizes that the spring's energy does not involve oscillation in this context. Understanding these points is essential for accurately applying thermodynamic principles to the spring's behavior.
lowbattery
Hello. I come across a problem: how to calculate the partition function of a classical spring whose energy is 1/2kx^2, and use thermodynamics to show that the force on the spring is linearly proportional to its elongation x?
I got stuck at the first step. What is the energy of the spring, is it (1/2)kx^2 or (1/2)(p^2/2)+(1/2)kx^2?
Really confused. Thanks in advance for answering the question!
I believe you're becoming confused between a spring and an oscillator. Although the question is vague, I don't think that the spring (and hence any mass attatched to it) is actually moving - this makes the (1/2)mv^2 term equal to zero.
So for a spring under a constant tension (i.e. no oscillation) will have energy (1/2)kx^2.
Hope this helps.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
