Partition function vs config integral
The discussion centers on the relationship between the partition function in classical statistical physics and its approximation using an integral over phase space. While the partition function is defined as a sum over energy states, this sum can be approximated by an integral when the variables are continuous. The choice of discretization factors, such as 1/(ΔxΔp), is debated, with some suggesting it can be approximated by Planck's constant to account for quantum effects. However, the key point is that constant factors drop out when taking derivatives of the logarithm of the partition function, making the approximation valid for practical purposes. Ultimately, the approximation holds better at high temperatures, where many energy states contribute significantly to the partition function.
aaaa202
In classical statistical physics we have the partition function:
Z=Ʃexp(-βEi)
But my book says you can approximate this with an integral over phase space:
Z=1/(ΔxΔp)3 ∫d3rd3p exp(-βE(r,t))
I agree that x and p are continuous variables. But who says that we are allowed to make this kind of discretization and what values are we choose for 1/(ΔxΔp)3 except for them being small?
I think my book is definitely hiding something from me, and using a rather lame argumentation in doing so.
For the most part, it doesn't matter. Everything that matters with the partition function comes from derivatives of log Z, which means that constant factors like 1/(ΔxΔp) will drop out. I've seen some books argue that (ΔxΔp) could be taken as approximately h or hbar, since that is sort of the "scale" of quantum effects.
But ln(Z1) is not equal to ln(Z2) when Z1=Ʃexp(-βEi) and Z2=∫d3rd3p exp(-βE(r,t)) ?
Yeah, it's an approximation. So it won't be exactly equal.
still don't understand. Let's say you want the derivative of Ln(Z). Then you are saying that:
∂(Ʃexp(..))∂β ≈ ∂ln(∫exp(...))/∂β
Yes, because choices of Δx and Δp drop out of such derivatives.
Large sums can often be approximated by integrals (are you familiar with the Riemann integral). For a typical partition function this approximation is not going to be very good at low temperatures, which you can see it in the math just from the fact at low temperature the terms for higher energy states have a very tiny contribution to the summation. But at high enough temperatures, where many terms contribute to the summation an integral can be a good enough approximation.
Maybe this will be a little more clear. The Riemann definition of the integral is something like this:
\int_0^\infty f(x) dx = \lim_{\Delta x \rightarrow 0} \sum_{n = 0}^{\infty} f(n \Delta x) \Delta x
Rewriting
\frac{1}{\Delta x}\int_0^\infty f(x) dx = \lim_{\Delta x \rightarrow 0} \sum_{n = 0}^{\infty} f(n \Delta x)
You can make this into an appoximation by dropping the limit:
\frac{1}{\Delta x}\int_0^\infty f(x) dx \approx \sum_{n = 0}^{\infty} f(n \Delta x)
This is often done the other way; the computation of an integral numerically on a computer is approximation as a summation.
okay makes sense. But since we are computing a partition function which sums over all states. How do we know what value to assign to Δx, or is this insignifanct as you say, because we are taking the log of Z?
Well, one argument is that ΔxΔp should be about h, since that is a quantity that gives a scale relevant to quantum effects. But yeah, it doesn't actually matter because we take the logarithms.
