Path integral applied to circular path
5 replies · 5K views
symmetric
Consider path given by equation [itex]( x - 1 )^2 + ( y - 1 ) ^2 = 1[/itex] that connect the points
A = ( 0 , 1 ) and B = ( 1 , 0 ) in xy plane ( shown in image attached ).
A bead falling under influence of gravity from a point A to point B along a curve is given by -
[tex]T = \int \frac{dt}{v}[/tex]
where the bead's velocity is [itex]v = \sqrt{2gy}[/itex] , where g is the gravitational constant.
Given curve [itex]( x - 1 )^2 + ( y - 1 ) ^2 = 1[/itex] can be parametrized as -
[itex]x - 1 = \cos\Theta[/itex]
[itex]y - 1 = \sin\Theta[/itex]
curve can be written as
[itex]c( \Theta) = ( 1 + \cos\Theta , 1 + \sin\Theta )[/itex]
[itex]c'( \Theta) = ( - \sin\Theta , \cos\Theta )[/itex]
[itex]\left| c'( \Theta) \right| = 1[/itex]
From given relation we have -
[tex]T = \int_{c} \frac{ \left| c'( \Theta) \right| d\Theta}{ \sqrt{2gy}}[/tex]
[tex]T = \int_{\pi}^{ \frac{3\pi}{2}} \frac{d\Theta}{ \sqrt{2g( 1 + \sin\Theta)}}[/tex]
[tex]As, 1 + \sin\Theta = \left( \cos\frac{\Theta}{2} + \sin\frac{\Theta}{2} \right) ^2[/tex]
[tex]T = \frac{1}{ \sqrt{2g}} \int_{\pi}^{\frac{3\pi}{2}} \frac{d\Theta}{ \cos\frac{\Theta}{2} + \sin\frac{\Theta}{2}}[/tex]
Changing variables ,
[tex]\frac{\theta}{2} = x , d\Theta = 2 dx[/tex]
[tex]T = \frac{1}{ \sqrt{2g}} \int_{\frac{\pi}{2}}^{\frac{3\pi}{4}} \frac{ 2 dx }{ \cos x + \sin x }[/tex]
[tex]As, \sin\frac{\pi}{4} = \cos\frac{\pi}{4} = \frac{1}{\sqrt{2}}[/tex]
multiplying Nr and Dr by [itex]\frac{1}{\sqrt{2}}[/itex]
[tex]T = \frac{1}{\sqrt{g}} \int_{\frac{\pi}{2}}^{\frac{3\pi}{4}} \frac{dx}{ \sin\frac{\pi}{4}\cos x + \cos\frac{\pi}{4} \sin x }[/tex]
[tex]T = \frac{1}{\sqrt{g}} \int_{ \frac{\pi}{2} } ^ {\frac{3\pi}{4}} \frac{dx} { \sin\left( x + \frac{\pi}{4} \right) }[/tex]
[tex]T = \frac{1}{\sqrt{g}} \int_{\frac{\pi}{2}}^{\frac{3\pi}{4}} \csc \left( x + \frac{\pi}{4} \right) dx[/tex]
[tex]T = \frac{1}{\sqrt{g}} \left| \ln \left[ \tan \left( \frac{ x + \frac{\pi}{4} } {2} } \right) \right] \right |_{\frac{\pi}{2}}^{\frac{3\pi}{4}}[/tex]
The value of first term after limit substitution is infinity. Here the value of integral i.e. ' time ' should be strictly finite. What is wrong with my solution?
where the bead's velocity is [itex]v = \sqrt{2gy}[/itex], where g is the gravitational constant.
"A bead is given by T=..." doesn't really make sense.
The problem is the integral you started with is wrong. You want a time, but if you check the units of the integral, you get time/(distance/time) = time2/distance.
What does t have to do with the curve?
Welcome to PF!
Hi symmetric! Welcome to PF! :smile:
(have a theta: θ and a pi: π and a square-root: √ and try using the X2 tag just above the Reply box :wink:)
Nooo … your own notation is bad, and you've misunderstood the question's notation. :redface:
i] never use t for a distance parameter, use s (or x etc)
ii] you don't need to use the usual θ (starting with θ = 0 along the positive x-axis) … you can choose any distance parameter, so you may as well start with θ = 0 at A, going to θ = π/2 at B
iii] the y in the given formula, √2gy, is not the y-coordinate, it's the difference in height (so at A it's 0).
Try again. :smile:​
D'oh! I just assumed t stood for time. Just ignore my earlier post. :blushing:
@vela @Hurkyl @tiny-tim
Thanks for your reply.
To clear confusion of variable 't' attaching original problem snapshot.
From my understanding of given question it's distance traveled along circular path ( specifically for above problem ) .
Try again. :smile:​
i] i generally don't use 't' for distance but given problem follows that notation .
ii] and iii] But we have to calculate transit time T for bead traveling along path given ( part of circle ). The given formula [itex]\sqrt{2gy}[/itex] is valid for any path ( circular, straight line etc ) with same start and end point. Hence, given curve must be parametrized in order to get transit time T along specific path. If we chose the parametrization mentioned by me, then [itex]\Theta = 0[/itex] and [itex]\Theta = \frac{\pi}{2}[/itex] will not leads to co-ordinates A(0,1) and B(1,0).
