Does the Pauli Exclusion Principle Imply Orthogonality of Quantum States?
In summary, the usual way of expressing the Pauli Exclusion Principle is that two identical fermions must be in different states, but this statement can be confusing as the meaning of "different states" is not clearly defined. It is more correct to say that the states of two identical fermions must be orthogonal, meaning that they have a zero transition probability. This is because the more fundamental fact is that the two-particle wavefunction must satisfy the antisymmetry property of \psi(x_1,x_2)=-\psi(x_2,x_1). Even if the states of the fermions are not eigenstates of a specific observable, the antisymmetry property ensures that their states must be orthogonal. However, once they are
jostpuur
2,116
Usual way of expressing pauli exclusion principle is, that the two identical fermions must be on different states. This seems a confusing statement, since the meaning of the term "different states" isn't very clear. Suppose I have two electrons, otherwise in the same states, but other one being spin up, and other one spin down. So the spin states are [tex](1,0)[/tex] and [tex](0,1)[/tex]. When I rotate the system about the x-axis with 90 degrees, the spin states become [tex](1,-i)/\sqrt{2}[/tex] and [tex](-i,1)/\sqrt{2}[/tex]. Now they are not in the "different states" in a naive sense, but this certainly cannot be a violation of the pauli exclusion principle. I can see that these vectors are still orthogonal. This was expected, since their orthogonality doesn't depend on the chosen representation. So wouldn't it be more correct to say, that the states of two identical fermions must be orthogonal? When I read and think at the same time, I see the expression "different states" meaning "orthogonal states". Is this correct?
The more fundamental fact is that the two particle wavefunction must satisfy the identity [tex]\psi(x_1,x_2)=-\psi(x_2,x_1)[/tex]. When two fermions are occupying states, whose spatial representations are [tex]\psi_1(x)[/tex] and [tex]\psi_2(x)[/tex], according to all books, the two particle wavefunction must be [tex]\psi(x_1,x_2)=(1/\sqrt{2})(\psi_1(x_1)\psi_2(x_2)-\psi_2(x_1)\psi_1(x_2))[/tex], so that the antisymmetry property is satisfied. The texts then say, that now we see that [tex]\psi_1[/tex] and [tex]\psi_2[/tex] must be different, because if they were the same the wavefunction would vanish. But how do you see that they must be orthogonal? Okey, if these states were eigenstates of some usual variable, everything would be fine, but if [tex]\psi_1[/tex] and [tex]\psi_2[/tex] are not eigenstates of some usual variable (like energy), then what? If antisymmetry of [tex]\psi(x_1,x_2)[/tex] implies orthogonality of [tex]\psi_1[/tex] and [tex]\psi_2[/tex], it can probably be shown with some calculation, but I haven't seen such anywhere.
It doesn't fully make sense to think particles occupying different (or orthogonal) states, since in the antisymmetrical wavefunction none of the particles is in some specific state. Still, in statistical stuff it is usually assumed that fermions simply are on the different states. Is this some kind of statistical approximation? You know, even if it wasn't fully correct, it would give correct statistical results and so on?
aren't you viewing from this from a different reference frame?
Should I now assume, that these questions do not even belong to the main stream physics? :confused:
if psi_1 and psi_2 is the same :
psi(x_1,x_2) = (1/sqrt2)[psi_1(x_1)psi_1(x_2) - psi_1(x_2)psi_1(x_1)]
and
psi(x_1,x_2) = (1/sqrt2)[psi_2(x_1)psi_2(x_2) - psi_2(x_2)psi_2(x_1)]
Yes that is correct. "Completely different" is expressed by the zero transition probability which in turn is expressed as zero (square of the ) inner product.
In truth it is not the vectors per se but the one dimensional complex subspaces they span which correspond to quantum modes (a.k.a. "states").
Completely distinct modes are orthogonal. Less than orthogonal modes overlap and hence systems prepared initially in one mode have a non-zero probability of being detected in the other mode.
You needn't worry about them being eigen-modes of a specific observable they are necessarily eigen-modes of some observable. You can anti-symmetrize two non-orthogonal modes but the result will eliminate the overlap.
Example suppose you have modes: [tex]\psi_1[/tex] and [tex]\psi_2[/tex].
Now suppose that [tex] \langle \psi_1|\psi_2\rangle = c[/tex]
We resolve [tex] \psi_2[/tex] as a superposition of parallel and perpendicular components:
[tex]\psi_2 = c\psi_1 + \psi_\perp[/tex]
i.e.[tex] \psi_\perp = \psi_2 - c\psi_1[/tex]
(I'm assuming [tex]\psi_1,\psi_2[/tex] have been normalized but you will note that [tex]\psi_\perp[/tex] is not!)
OK so far?
Now consider the anti-symmetric product:
[tex] \Psi =\psi_1\wedge\psi_2\equiv \psi_1\otimes\psi_2 - \psi_2 \otimes\psi_1[/tex]
[tex] = \psi_1\otimes(c\psi_1+\psi_\perp) - (c\psi_1+\psi_\perp)\otimes\psi_1[/tex]
[tex] = c\psi_1\otimes\psi_1 -c\psi_1\otimes\psi_1 + \psi_1\otimes\psi_\perp-\psi_\perp\otimes\psi_1[/tex]
[tex] = \psi_1\wedge\psi_\perp[/tex]
(Again note that since the two normalized vectors were not orthogonal then their anti-symetrized product will not be normalized!)
(Note you can similarly expand the first in terms of perp and parallel components to the second.)
Thus in essence if you combine two fermions the anti-symmetry dictates that the composite structure will be the same as for two orthogonal fermions. However you do need to be slightly careful about saying each is orthogonal to the other. Once you use the anti-symetrized composite it isn't quite proper to speak of individual particles as if they were distinguishable except by using values of a physical observable as a label.
Your are right as I noted above. But think of it as short hand for saying "they are equivalent to a composite of two in orthogonal modes".
(You'll notice I'm careful to say mode instead of state or to quote state. The Hilbert space vector refers to an equivalent mode (method) of preparation and not an objective state. It is important to keep that distinction in mind when parsing through some examples such as EPR experiments.)
Regards,
James Baugh
Let us consider the states of the particles. Can the particles somehow sense that there is a similar particle with the same spin in close proximity and somehow manage to repel the other particle? That idea is not tenable. Let's instead consider that the PEP arises from the inability of the vacuum to support the existence of two similar same-spin particles concurrently. Christine Dantas has recently brought up the concept of concurrency WRT quantum physics and I think its a great area of inquiry. Here is part of a recent email.
turbo-1 said:
Yes, the Pauli Exclusion Principle is interesting in a number of ways. If you look at fermions as if they were particles, you might think that somehow these particles have some kind of property that exhibits a resistive force when they are forced into proximity with similar particles with the same
spin. I think it is more productive to think of fermions as waves in the fabric of the quantum vacuum, and the PEP is a demonstration of the inability of the vacuum to support two of these similar waves in the same quantum state. When I read your musings on concurrency, it made me think of how quantum concurrency could be manifest in experimental settings. That's when the PEP popped up - it seems to be a good fit, and for me it demonstrates the wave nature of matter vs the "atomistic" view of matter as a conglomeration of particles. A particle view of fermionic repulsion via the PEP cannot be explained unless we are willing to invent a repulsive force that arises when a fermion "knows" that it is being forced into proximity with a similar particle. It's much simpler to consider that the existence of a fermionic wave in a small volume of the quantum vacuum inhibits the possibility that a similar entity can exist nearby, and at some mimimum volume the vacuum lacks the resources to permit the existence of two such similar matter waves, and at that limit the existence of a second similar fermion in that space is practically impossible. This way, we can dispense with the motion of fermionic repulsion (with another weird force to mess up the model) and fall back on the quantum notion that the existence of a subatomic particle can be described as a probability function. As the probability function for a matter wave's existence peaks around a particular location (very static thought-experiment), the probability function for the existence of a second functionally identical entity is at a minimum. Therefore the PEP is a demonstration of the properties of the quantum vacuum, and not of the fermions embedded in it.
Some other musings.
You can think of the phenomenon of stimulated emission as a corresponding "inclusion principle" dual to the PEP.
Also while doing some deeply mathematical research with my thesis advisor, we pondered whether one could recast all physical forces as statistical in nature in the sense that the PEP effects a virtual repulsive force. Note that in neutron stars this repulsive force becomes very physical in effect.
Also note that when we look at forces from a quantum perspective they are all expressible as "interference effects" in the "sum over histories" formulation. So who is to say PEP "repulsion" isn't a real force?
Regards,
James Baugh
jambaugh, I'm glad to see those equations conserning antisymmetric wavefunctions. In fact I had made similar remarks on my own, but I was afraid that I was coming up with "my own stuff" (once again), since the books and notes I've seen do not discuss this matter. Now when I've started to think about this more, I think this is starting to make sense, and I've hit a following, a rather mathematical, idea:
A two particle wave function [tex]\psi(x_1,x_2)[/tex] is not a unique way of representing a two fermion state, but instead we can define an equivalence relation [tex]\psi\sim\psi'[/tex] meaning that
[tex]\psi(x_1,x_2)-\psi(x_2,x_1) = \psi'(x_1,x_2)-\psi'(x_2,x_1)[/tex]
and then it is the equivalence class [tex][\psi][/tex], represented by some wave function [tex]\psi[/tex], that is really the relevant physical object, and what defines the state.
How correct is this?
The equivalence relation was motivated by a remark, that when an arbitrary wave function is written in a form
[tex]
\psi(x_1,x_2)=\frac{1}{2}(\psi(x_1,x_2)-\psi(x_2,x_1)) + \frac{1}{2}(\psi(x_1,x_2)+\psi(x_2,x_1)),
[/tex]
the symmetric part vanishes in the expression
[tex]
\int dx_1\; dx_2\; \psi(x_1,x_2) a^\dagger_{x_1} a^\dagger_{x_2}|0\rangle
[/tex]
if creation operators satisfy the usual anticommutation relation.
1. What is the Pauli principle and how does it relate to confusion?
The Pauli principle, also known as the Pauli exclusion principle, is a fundamental principle in quantum mechanics that states that no two identical fermions (particles with half-integer spin) can occupy the same quantum state simultaneously. This principle can lead to confusion because it can be difficult to understand how particles can have different quantum states when they are considered identical.
2. Why is the Pauli principle important in understanding the behavior of atoms and molecules?
The Pauli principle is important because it explains the stability of atoms and the formation of chemical bonds in molecules. Without this principle, electrons would all occupy the lowest energy state, resulting in unstable atoms and molecules. The Pauli principle allows for the arrangement of electrons in different quantum states, leading to a more stable and diverse range of chemical elements and compounds.
3. How does the Pauli principle affect the arrangement of electrons in an atom?
The Pauli principle dictates that electrons must occupy different quantum states, with no more than two electrons in each state (one with spin up and one with spin down). This leads to the familiar electron configuration of atoms, where electrons fill up energy levels in a specific order, starting with the lowest energy state and moving up from there.
4. Can the Pauli principle be violated?
No, the Pauli principle is a fundamental law in quantum mechanics and has been experimentally verified numerous times. It is considered a fundamental principle of the universe and cannot be violated.
5. How does the Pauli principle differ from the exclusion principle proposed by Wolfgang Pauli?
The exclusion principle proposed by Wolfgang Pauli in 1925 is the same as the Pauli principle in quantum mechanics. However, the term "exclusion principle" is now used more broadly to refer to any principle that states that particles of the same type cannot occupy the same quantum state simultaneously, not just in quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
