Pdf of weighted uniform random variables
5 replies · 2K views · last reply
PAHV
Let x(1),...,x(N) all be independent uniformally distributed variables defined on (0,1), i.e. (x(1),...,x(N)) - U(0,1). Define the random variable y(i) = x(i)/(x(1)+...+x(N)) for all i=1,...,N. I’m looking for the pdf of the random variables y(1),…,y(N). Has anyone come across such random variables? If so, any references would be appreciated!
I don't think it's too hard to work out. Start with deriving the CDF. P[Yi < y] = P[x(i)/(x(1)+...+x(N)) < y] = etc.
Is the question about the joint distribution of the [itex]y_i[/itex]?
Yes, the question is about the joint distribution of the y(i). Any help on getting started with the pdf is highly appreciated!
Hey PAHV and welcome to the forums.
If N is large enough, then you can approximate the sum by using the Central Limit Theorem (i.e. normal) approximation.
If not (or you are particular on having everything precise), then use the standard tools for calculating sum/ratio distributions.
