Peeved about a simple Sample Mean question
  • Thread starter Thread starter trap101
    Mean
trap101
Let X(bar)[sample mean] be the average of a sample of 16 independent normal random variables with mean 0 and variance 1. Determine c such that
P(|X(bar)| < c) = 0.5
Ok here's the problem, I know this is SUPPOSED to be a simple computation but for one reason or another little ol' fooliosh me can't figure it out.
Since we are dealing with X(bar) I figure it is defined as 1/n\sum(from 1 to n) Xi
now since we're talking abiout 16 independent Normal random variables, I figured it would be as easy as taking the sum of all of these normals and solving for x. Well according to the solution this isn't the case.
Another thing I tried was taking the product of the iid normals:
1/(2\pi\sigma<sup>2</sup>)1/2 e\sum(Xi2)/2
set this equal to 0.5 and solve for X. Again the wrong answer. Help please
If
$$Y = \frac{1}{N}\sum_{n=1}^{N} X_n$$
then what can you say about ##Y##? What kind of random variable is it? What are its mean and variance?
You seem to be completely misunderstanding the problem! What you should be doing is using the theorem:
"The average of n random variable, each having normal distribution with mean \mu and standard deviation \sigma, has the standard deviation with mean ]\mu and standard deviation \frac{\sigma}{\sqrt{n}}. "
The problem is simply asking you to find c the probability of that "X" is less than c is 0.5 when X has the normal distribution with 0 and standard deviation 4. That can be done by looking up "z" such that P(z)< 0.5 on a table of the standard normal distribution
(A good one online is at http://www.math.unb.ca/~knight/utility/NormTble.htm )
and then solving \frac{x}{4}= z.
(You really shouldn't need a table to find z such that P(z)< 0.5!)
(I say after looking it up in the table myself!:redface:)
The average of n random variable, each having normal distribution with mean \mu and standard deviation \sigma, has the standard deviation with mean \mu and standard deviation \frac{\sigma}{\sqrt{n}}.
Ok, I got the right solution, but I got it extremely flukey...Let me see if I make sense of it.
So looking at the table of the standard normal distribution, for the value of 0.5 I got a probability of 0.6915. Taking this 0.6915 I put it into the expression of \frac{x}{4}= z and got a value of 0.1728 for z. A couple questions: the 0.6915 is the percentage in relation to the z-score of 0.5? and what exactly was the motivation behind dividing 0.6915 by 4? Sure the answer might be right but what was that expression representing?
The sample mean ##\bar{X}## is normally distributed, has expected value = 0 and variance ##\sigma^2=16##, so has standard deviation ##\sigma = 4##. That is, we can write
\bar{X} = \frac{Z}{\sigma} = \frac{Z}{4},
where ##Z \sim N(0,1).## So,
P\{ |\bar{X}| &lt; c \} = P\{ -c &lt; \bar{X} &lt; c \} = P\{-c &lt; Z/4 &lt; c\}.
\bar{X} = \sigma Z = 4 Z,
P\{ |\bar{X}| &lt; c \} = P\{ -c &lt; \bar{X} &lt; c \} = P\{-c &lt; 4 Z &lt; c\}.
ok, just to make sure this is a legitimate move I'm going to make we have established:
P\{-c &lt; 4 Z &lt; c\}. = 0.5
now looking at the tables, for a Standard Normal distribution, the value of "c" is satisfied by 0.6915.
Therefore: P\{-0.6915 &lt; 4 Z &lt; 0.6915\}. = 0.5, but since this is not fully standardized I have to divide by the 4:
therefore:
P\{-0.6915/4 &lt; Z &lt; 0.6915/4\}.
which gives me 0.1728. Is this the right set of steps?
therefore:
Sorry: I meant that variance is 1/16 and ##\sigma = 1/4##. We have ##\bar{X} = \sigma Z = Z/4,## so the probability is ##P \{ -c < Z/4 < c \} = P \{ -4c < Z < 4c \}##.
therefore:
Your answer is 16 times too small.
Please disregard this message, and instead refer to the others I gave. I wanted to delete this message, but the system won't allow it. Basically, ##\bar{X} = 4 Z##, NOT what I wrote immediately above.
