How Does Temperature Influence Grandfather Clock Timing?
  • Thread starter Thread starter gapgirl1010
    Clock Pendulum
gapgirl1010
How does temperature affect grandfather clocks? A metal rod pendulum is inside of the clock. I have a question regarding this. If an expirement happened where 3 clocks were sent to the same time. ONe was put in a cold room, one in a hot, and one in a room temperature room. What would the cold room grandfather clock and the hot room grandfather clock say if the room temperature clock was 3 o'clcok? PLease help me! EXPLAIN
You know that the period of a pendulum depends on its length. What happens to the length of a pendulum under the conditions you specified?
P.S. I won't even point out that all three rooms, by definition, are at "room temperature!" :)
I am guessing that the metal rod expands when the room is hotter and "shrinks" when the room is colder. If the length is a dependant factor, wouldn't the period affect it becuase the rod lengthens and condenses?
Am I right with the whole lengthening thing?
Yes! You know that a longer pendulum has a longer period than a shorter one so you should now be able to completely answer the question.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
