Is the Wave Equation Invariant Under a Lorentz Boost?
The discussion focuses on demonstrating the invariance of the wave equation under a Lorentz boost along the x-direction and its non-invariance under a Galilei transformation. Participants emphasize the need to apply the chain rule correctly to express derivatives in the new coordinates. A common challenge is recognizing the multivariable nature of the problem rather than treating it as a single-variable issue. The transformation equations for time and space coordinates are provided, highlighting the role of the Lorentz factor. Ultimately, proper application of the chain rule is crucial for successfully proving the invariance of the wave equation.
B-80
i) Show that the wave equation:
[( -1/c^2) d^2/dt^2 + d^2/dx^2 + d^2/dy^2 + d^2/dz^2 ]u(t,x,y,z) = 0
is invariant under a Lorentz boost along the x-direction, i.e. it takes the same form as a partial differential equation in the new coordinates. [Use the chain rule in two variables.]
ii) Show that the wave equation is not invariant under a Galilei transformation.
second order partial derivative equation. I can't get Latex to work right now, or I'd write it out, here's a link to it on another thread https://www.physicsforums.com/showthread.php?t=216869
g=gamma, the lorentz factor
x'=g(x-vt)
y'=y
z'=z
t'=g(t-v x/c^2)
So I just haven't ever done this, and I am not super sure where to start.
I tried rearranging the x' and t' eqs to read
x=x' / g + vt
and
t=t'/g +vx/c^2
then using the chain rule which gave me
dt/dt' = 1/g
and
dx/dx' = 1/g
with both the second derivatives being 0
Plugging that into the equations gave me an extra factor of 1/g^2 on the second derivatives with respect to x and t. I am fairly certain this is the wrong approach anyway. I just don't know where to plug what.
I know this is 100% a math exercise, but it's my HW, and I figure this is the best place to put it.
edit: I realized that this is a multivariable problem, and I have been treating it as a single variable problem i.e. u=u(x'(x,t),y',z',t'(x,t))
and therefore
du/dx = (du/dx')(dx'/dx)+(du/dt')(dt'/dx)
but now if I want to take the second derivative of that i.e.
d^2/dx^2 u = d/dx [(du/dx')(dx'/dx)+(du/dt')(dt'/dx)]
how do I evaluate d/dx(du/dx') and d/dx(du/dt') I know to product rule the rest, but i don't quite remember if there's anything fancy about taking the derivative of a function with respect to a variable whose already had it's derivative taken by function depending on that variable.
dt/dt' = 1/g
and
dx/dx' = 1/g
You need to do more than this. You've probably already seen this type of calculation before when converting differential equations to polar or spherical coordinates. You need to use the chain rule to write the derivatives with respect to the old coordinates in terms of the derivatives with respect to the new coordinates. For example
\frac{\partial}{\partial t} = \frac{\partial t'}{\partial t}\frac{\partial}{\partial t'} + \frac{\partial x'}{\partial t}\frac{\partial}{\partial x'} + \frac{\partial y'}{\partial t}\frac{\partial}{\partial y'} +\frac{\partial z'}{\partial t}\frac{\partial}{\partial z'},
with similar expressions for the spatial derivatives. Many terms will vanish because of the specific form of the coordinate transformation.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
