Perimeter & Area: Which Structure Has Largest/Smallest?
  • Thread starter Thread starter paul.redgate
    Area Perimeter
The discussion revolves around a test question comparing the perimeters of four one-story buildings—a square, rectangle, L-shaped structure, and circle—all with the same area. The key inquiry is which structure has the largest and smallest perimeter. Relevant equations for area and perimeter are sought, particularly how they relate to each shape. It is noted that the perimeter of a rectangle can differ from that of a square with the same area. Understanding these relationships is crucial for determining the correct answers to the test question.
paul.redgate
I had a question on a test & could not get an answer and was wondering if someone might have a clue. The question presented four buildings--a square, rectangle, L-shaped building and circle. All of the buildings are one-story and have the same area. The question was which structure had the largest perimeter & which had the smallest perimeter. None of the multiple choice answers were none of the above or all of the above. Any help would be greatly appreciated.
What are the relevant equations? What is the area of a circle in terms of its diameter? In terms of its perimeter? What is the area of a square in terms of its perimeter (or more to the point, its perimeter in terms of its area)? Same question for a rectangle -- is a rectangle's perimeter bigger or smaller than a square with the same area?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
