Periodicity of Fourier's heat theory
  • Thread starter Thread starter jaredokie
    Heat Theory
jaredokie
Can I please get some help in understanding how Fourier developed his idea of heat transfer being a periodic phenomena?
I don't know what you mean by that. Heat is NOT a "periodic phenomenon" and Fourier never said it was. You may be mistaking Fourier series (infinite sums of sine and cosine) with finite sums. Finite sums of periodic functions are periodic. Infinite sums are not.
So why did he use sine and cosine functions for heat analysis? Orthogonal reasons?
Because sine and cosine are the solutions of the equations for the spatial variation which arise from separation of variables in the heat equation.
Ok. I'm sorry for being dense, but what do you mean by spatial variation?
The wave equation is
\frac{\partial^2 \phi}{\partial x^2}= \frac{1}{c^2}\frac{\partial^2\phi}{\partial t^2}
If you use "separation of variables" you would look for solutions of the form \phi(x, t)= X(x)T(t) (separating x and t into separate functions) so that the equation becomes
T\frac{d^2X}{dx^2}= \frac{1}{c^2}X\frac{d^2T}{dt^2}
Divide both sides by XT to get
\frac{1}{X}\frac{d^2X}{dx^2}= \frac{1}{c^2T}\frac{d^2T}{dt^2}
Now the left side is a function of x only and the right side is a function of t only. In order to be the same for all x and t, each side must be equal to a constant:
\frac{1}{X}\frac{d^2X}{dx^2}= \lambda
\frac{d^2X}{dx^2}= \lambda X
This is what pasmith is referring to as the "spatial variation".
IF we are given the heat problem on a finite interval, say T(0)= T(P)= 0, then we can show that the "spatial dependence", the function X(x), must have sine and cosine solutions.
If, for example, \lambda= 0 this becomes just d^2X/dx^2= 0 so the general solution is y= Ax+ B which is NOT periodic and so cannot satisfy the boundary conditions.
If, for example, \lambda> 0 the general solution is y= Ae^{x\sqrt{\lambda}}+ Be^{x\sqrt{\lambda}}.
So \lambda must be negative. If we write \lambda= -\alpha^2, the equation becomes d^2X/dx^2= -\alpha^2 X, which has general solution Acos(\alpha x)+ B sin(\alpha x). That's where the
\frac{1}{c^2T}\frac{d^2T}{dt^2}= \lambda
\frac{d^2T}{dt^2}= \lambda c^2T
Again, that is for the heat problem on a finite interval. If we had and infinite interval, say the heat equation on x\in [0, \infty), the solutions are Fourier Transforms, not Fourier series, and are NOT periodic at all.
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
