Permanent magnets and "permeance"
In summary, permanent magnets are objects that produce a magnetic field without the need for an external power source. They are made from ferromagnetic materials and are able to maintain their magnetic properties over a long period of time. The strength of a permanent magnet is measured by its "permeance," which is a measure of the magnet's ability to maintain its magnetic field against external forces. Permeance is influenced by factors such as material composition, shape, and temperature. Permanent magnets are commonly used in a variety of applications such as motors, generators, and magnetic storage devices due to their reliable and long-lasting magnetic field.
hollowman
23
TL;DR Summary
I have an indoor recumbent exerciser bike that uses a non-contact magnetic "clutch" for resistance.
There is permanent-magnetic fulcrum assembly that pivots on a hinge. And a heavy iron flywheel that spins when pedaling. The arc moves toward/away from flywheel based on resistance setting.
I've had the bike for about 10 years and have noticed that I have had to increase the resistance setting in order to achieve the SAME resistance. I added some neodymium magnets to the fulcrum, which restored resistance somewhat.
So the question is about permeance. How long do permanent magnets last in nature, given constant room temperature? Also, what about that iron flywheel. Does its proximity (errrr... magnetic "drag") have de-magnetizing effects?
hollowman said:
Summary:: Permanent magnets and "permeance"
I think you mean more "permanence" and not permeance. Permeance is a different concept (the inverse of magnetic reluctance):
https://en.wikipedia.org/wiki/Permeance
It looks like vibration would be the main reason that your permanent magnets lost some of their magnetization over time:
https://www.magnetassemblies.com/permanent-magnets/
Non-permanent magnets are electromagnets which require an external electric current to trigger magnetism or non-magnetism. Permanent magnets, on the other hand, retain their magnetism indefinitely or until they are demagnetized by vibration, dirt, corrosion or interfering magnetic fields. Read More…
EDIT/ADD -- Although I suppose it might be possible for the eddy currents in the flywheel to cause some demagnetization of the permanent magnets over time. Will have to do some Googling about that...
Likes hollowman
Wow. Thanks @berkeman. I didn't know that.
Another way to think about the issue would be, all else held equal, how long to would magnetic domains remain "in static position" if the fridge magnet or audio cassette tape were isolated in some remote, inter-cluster corner of the universe?
In electromagnetism, permeance is the inverse of reluctance. In a magnetic circuit, permeance is a measure of the quantity of magnetic flux for a number of current-turns.
Googling "magnetic permanence" returns results about "magnetic remanence" which is more relevant to your question about the loss of magnetism.
See also: https://sciencing.com/causes-magnet-lose-its-magnetism-8229455.html
Likes berkeman
And/or "Coercivity", https://en.wikipedia.org/wiki/Coercivity
" also called the magnetic coercivity, coercive field or coercive force, is a measure of the ability of a ferromagnetic material to withstand an external magnetic field without becoming demagnetized"
Another thing to note is that in engineering (especially industries related to permanent magnets/magnetism, like TDK), "permeance" is used as follows:
"in calculating a magnetic circuit, permeance P, which is the reciprocal of magnetic resistance R" ...
https://product.tdk.com/info/en/products/magnet/technote/designguide.html
"Permeance coefficient Pc is used to express the operating point of the magnet on the B-H curve. This value is defined as the ratio of magnetic flux density Bd and magnetic field strength Hd at the operating point."
Likes hutchphd
Going over some web articles, it's possible that the bike's ferrite magnets were, over time, also affected (demag'd) by the Earth's mag. field.
Likes hollowman and anorlunda
Tom.G said:
Cheers,
Tom
Thx.
It would still be helpful if there were a more definitive or rigorous description or quantification -- beyond the somewhat roundabout terminology thrown around this thread, like "permeance". Maybe the "magnetic stuff" or "magnetic mass" of a NATURAL permanent magnet is something like the Higgs Field? Maybe "magnetic field is a vector field" or "tesla" or "webers" (as noted in resources like Wiki).
When measuring mag fields, one can use instruments such as [gauss meter]:
Also see:
https://www.magnet-sdm.com/2017/08/01/magnetic-field-strength-permanent-magnet/
1. What is a permanent magnet?
A permanent magnet is a material that produces its own magnetic field and retains its magnetism over a long period of time. It is typically made of ferromagnetic materials, such as iron, nickel, or cobalt.
2. How are permanent magnets made?
Permanent magnets are made by exposing ferromagnetic materials to a strong magnetic field, aligning the magnetic domains within the material. This creates a permanent magnetic field within the material.
3. What is permeance?
Permeance is a measure of the ease with which a magnetic field can pass through a material. It is the reciprocal of reluctance, which is a measure of the resistance to the flow of magnetic flux.
4. How is permeance related to permanent magnets?
Permeance is related to permanent magnets because it determines the strength of the magnetic field produced by the magnet. A material with high permeance will allow more magnetic flux to pass through it, resulting in a stronger magnetic field.
5. Can the permeance of a permanent magnet be changed?
No, the permeance of a permanent magnet cannot be changed. It is an inherent property of the material and is determined by its composition and structure. However, the strength of the magnetic field produced by the magnet can be changed by altering the shape or size of the magnet.
  • Mechanics
  • Classical Physics
  • Electrical Engineering
  • General Engineering
