What Is the Drude-Lorentz Model in Relation to Permittivity and Conductivity?
In summary, the conversation discusses a relationship between permittivity and conductivity, expressed as \epsilon(\omega) = 1 + \frac{4\pi\iota\sigma(\omega)}{\omega}. The speaker is unsure of how the relationship was derived and asks if it has a name or derivation to refer to. They also mention that they believe the units to be in cgs and ask for the equivalent in SI units. The responder suggests that the relationship could be similar to the definition of "complex permittivity" and provides a link for reference.
thefireman
I have an relation between permittivity and conductivity as follows:
[tex]\epsilon(\omega) = 1 + \frac{4\pi\iota\sigma(\omega)}{\omega}[/tex]
Yet am unclear as to how it was derived. Does this relationship have a name and/or derivation to follow through somewhere? also, I believe it is cgs units, what is the SI equivalent?
Thanks
Thanks
Hi thefireman! :smile:
(i think you just leave out the 4π … or is it 4πe0 ? … to get SI units)
this looks a bit like like the "complex permittivity" definition …
[tex]\hat{\epsilon}(\omega)\ =\ \epsilon(\omega) + \frac{\iota\sigma(\omega)}{\omega}[/tex] is the "complex permittivity"
… see eg http://en.wikipedia.org/wiki/Permittivity#Lossy_medium
… but with a different notation
for sharing this relationship between permittivity and conductivity. This relationship is known as the Drude-Lorentz model, which was developed by physicist Paul Drude and Hendrik Lorentz in the late 19th century. It is used to describe the behavior of electrons in a material and their interaction with an electromagnetic field.
The derivation of this relationship can be found in many textbooks on electromagnetism or solid state physics. It involves solving the equations of motion for electrons in a material under the influence of an external electric field. The result is a complex permittivity, which includes both the real part (related to the dielectric properties of the material) and the imaginary part (related to the conductivity of the material).
In SI units, the equivalent relationship is:
\epsilon(\omega) = \epsilon_0 + \frac{\sigma(\omega)}{\iota\omega}
where \epsilon_0 is the vacuum permittivity. This is just a matter of converting the units from cgs to SI.
I hope this helps clarify the relationship between permittivity and conductivity and its origins. It is a fundamental relationship that is used in many areas of physics and engineering, particularly in the study of electromagnetic waves and materials.
What is permittivity?
Permittivity, also known as electric constant, is a measure of a material's ability to store an electric field. It is represented by the symbol ε and is measured in farads per meter (F/m). It is a fundamental property of a material and determines how much charge can be stored in the material for a given electric field.
What is conductivity?
Conductivity is a measure of a material's ability to conduct electricity. It is represented by the symbol σ and is measured in siemens per meter (S/m). It is the inverse of resistivity, which is the measure of a material's resistance to the flow of electric current.
How are permittivity and conductivity related?
Permittivity and conductivity are related through a mathematical equation known as the complex permittivity formula. This formula takes into account the permittivity and conductivity of a material to determine its dielectric properties. In general, materials with high permittivity tend to have low conductivity, and vice versa.
What factors affect permittivity and conductivity?
The permittivity and conductivity of a material can be affected by various factors such as temperature, frequency of the electric field, and the presence of impurities or defects. In general, permittivity and conductivity tend to increase with temperature and frequency, while the presence of impurities or defects can decrease them.
How are permittivity and conductivity measured?
Permittivity and conductivity are typically measured using specialized instruments such as a capacitance meter or a conductivity meter. These instruments apply an electric field to the material and measure the response, which is then used to calculate the permittivity and conductivity values. Other techniques, such as dielectric spectroscopy, can also be used to measure these properties over a range of frequencies.
  • Other Physics Topics
  • Math Proof Training and Practice
