Permutations Physics Problem: Calculating ab from Given Permutations
duki
a = (162)(45)
b = (123)(46)
c = (1362)
Find: ab
k, so for a i have this:
| 1 2 4 5 6 |
| 6 1 5 4 2 |
and for b i have this:
| 1 2 3 4 6 |
| 2 3 1 6 4 |
so when I started doing the multiplication I got to '4 -> 5, 5 -> ??'
What am I doing wrong?
here's what I have so far:
| 1 2 4 5 6 |
| 4 2 |
Work from right to left. First 4 goes to 6 by b, then 6 goes to 2 by a.
You need to follow the chart and think of permutation as replacing one term with another.
so you have:
b=| 1 2 3 4 6 |
| 2 3 1 6 4 |
a=| 1 2 4 5 6 |
| 6 1 5 4 2 |
If you need a way to sort this, then write down as ab(5)=a(b(5))=a(5)=4.
I'm not sure I understand... by going from b -> a I would be doing ba not ab, which aren't equivalent?
am i missing something?
doesn't it cycle through the numbers...
ie (162) means (1) goes to position (2), then position (6) goes to (1), and (2) to (6)
So with all six number in the chart
and for a = a_II.a_I = (1,6,2)(4,5) apply right hand permutation first gives
|1 2 3 4 5 6|
apply a_I = (4,5)
|1 2 3 5 4 6|
apply a_II = (1,6,2)
|6 1 3 5 4 2|
I don't think permutations necessarily commute, think of (1,2) and (2,3), but try it and see
a = a_II.a_I is actually a set of 2 permutations which do commute, so it doens't matter which is done first
for a.b i would apply b first then a
so b.a = (162)(45)(123)(46)
To write out the result simply, start with where (1) has moves & track each number as it moves through the set from, when you move a number back to (1) that ends that permutation chain & look at the remaining numbers.
Are you working in S_6={1,2,3,4,5,6}? If you know the set being permuted, then 1-cycles aren't included in cycle notation. a takes 3 to 3, which is understood since 3 isn't included in a cycle. You would write a as
| 1 2 3 4 5 6 |
| 6 1 3 5 4 2 |
Similarly, b takes 5 to 5. It seems like not including these is giving you problems. Also, check your book to see if (ab)(x) is defined as a(b(x)) or b(a(x)). I've only seen it defined as a(b(x)), which is why everyone is telling you to work right to left and do b first, but I think some people define it as b of a.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
