Perpendicular Inelastic Collision
In a completely inelastic collision involving two clay balls of equal mass, one moving at 5.6 m/s and the other at 7.8 m/s perpendicularly, the momentum of the combined balls after the collision can be calculated using vector addition. The momentum before the collision is determined by the formula P = (P1^2 + P2^2)^(1/2), where P1 and P2 are the momenta of each ball. The total mass after the collision is the sum of the two masses, 0.48 kg. The user initially calculated the final velocity incorrectly as 6.7 m/s and seeks clarification on the correct approach. Understanding the vector nature of momentum is crucial for solving this problem accurately.
sheepcountme
Two clay balls of the same mass stick together in an completely inelastic collision. Before the collision, one travels at 5.6 m/s and the other at 7.8 m/s, and their paths of motion are perpendicular. If the mass of each ball is 0.24 kg, what is the magnitude of the momentum of the combined balls after the collision?
Vf=(m1v1+m2v2)/(m1+m2)
I plugged everything in and for Vf I got 6.7, which was incorrect. Could someone tell me where I went wrong...
Before collision two clay balls are moving in the perpendicular direction. So the resultant of two momenta is P = (P1^2 + P2^2)^1/2.
Therefore the momentum after collision is P. Total mass M is (m1 + m2). Now find Vf.
Thank you!
