Perturbation theory in strong interaction regime
gonadas91
In QFT, we can expand the propagator and obtain the diagrammatic expansion to build up the Green's function. If we have a hamiltonian of the type H = H_{0}+V, where V is the perturbation, we can build up the Feynman diagrams,and if we could build up all of them to infinite order, we would obtain the exact Green's function on the model.
However, my question is related with the fact that, in all the formal development of the diagrammatic expansion, V is not assumed to be "small" compared with H0, I mean is a perturbation which in principle is always assumed to be small respect to H0. But what happens if V becomes larger and of the same magnitude as H0? If we go to infinite order of perturbation, do we still have the exact Green's function of the problem?
This is not true. The perturbation series always diverges at some level, since it is an asymptotic series. This is essentially due to the number of diagrams growing faster than the suppression from the powers of the coupling (##\sim \alpha^n## vs ##\sim n!##).
Depending on the coupling strength and (to some extent) on the available vertices, the asymptotic series is going to start diverging at different orders in perturbation theory. If the coupling constant is strong you will essentially never have a good approximation.
But I can't still see why going to infinite order is not giving the exact solution of the problem. I mean, if we are at zero temperature, you use the Gell-Mann Low theorem to perturb the system from the non-interacting ground state to the interacting one. This expansion is made by exact calculation of the S matrix, which is an exponential operator and you just express the exponential as a series, where the different contractions give you different diagrams. During all this treatment and derivation of the diagrammatic expansion for the Green function, its never said that V has to be necesarilly small compared to H0.
Further and for the sake of completeness, which are the available methods in many body theory to treat strong correlated systems apart from perturbation theory and RG? The RG methods also derive an approximation of the solution or they give in fact the actual solution?
Some real physical effects are essentially non-perturbative and never show up at any order in perturbation theory. For example suppose you try to do a power series expansion of ##\exp(-1/g^2)## around ##g = 0##. You'll find that you can't; this function has an essential singularity at ##g = 0##. And some physical effects are proportional to ##\exp(-1/g^2)## where ##g## is a coupling. Such effects--for example instantons and tunneling--will never show up in the perturbative power series expansion around ##g=0##. A classic example is a harmonic oscillator with a ##\lambda x^4## perturbation. For ##\lambda < 0## the system because unstable due to tunneling, but perturbation theory never detects this.
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
