Understanding Litmus: pH Indication with Lichens and Dyes
  • Thread starter jackson6612
  • Tags
    Ph
In summary, the conversation discusses the basics of litmus and its use as an indicator for acidity and basicity tests. It is made from a water-soluble mixture of dyes extracted from lichens, which are composite organisms. Litmus is reversible when used in acidity/basicity tests, but irreversible when used for testing other reactions. The idea of using lichens as a source of dyes may have originated from the medieval fascination with the color purple.
jackson6612
334
I'm not a chemistry student. So, I humbly request you to limit yourself to the basics, please do not indulge in infighting. If you ignore the request, you would be investing your efforts at the wrong place and perhaps it would be considered a pretentious show of knowledge.
Litmus is a water-soluble mixture of different dyes. It works between the pH range 4.5-8.3. To cover the full of spectrum of pH, 1-14, universal indicator is used.
The dyes used in the litmus are extracted from lichens, especially Roccella tinctoria.
Lichens are composite organisms consisting of a symbiotic association of a fungus with a photosynthetic partner, usually either a green alga or cyanobacterium.
Here dye is certain chemical which can be single molecule or a group of different molecules and behaves in a particular way under different pH conditions.
1: As it is stated above that the litmus can only used when the range is between 4.5-8.3, what would happen to the litmus or dyes or their color patterns when pH is outside this bound?
2: How did someone come up with the idea that some weird composite organisms called lichens can be used to tell the acidity of the solution? It was not like that someone accidently dropped few grains of table salt or sugar into the solution and discovered that it could be used for acidity test.
Wikipedia says: Chemical reactions other than acid-base reaction can also cause a color-change to litmus paper. For instance, chlorine gas turns blue litmus paper white – the litmus paper is bleached. This reaction is irreversible and therefore the litmus is not acting as an indicator in this situation.
3: What does it mean by 'irreversible' here? Perhaps, it means that chlorine somehow permanently damages the dyes and even if it is evaporated or removed fully, the dyes wouldn't retain their original property and couldn't be used for the test again.
Chemistry news on Phys.org
1) Litmus can be used outside the 4.5-8.3 range. It will be red below 4.5 and blue above 8.3
2)Well, I'd say it was just a coincidence: someone dropped in an acid or base and found out that it changes collors. I think it would be hard to derive from first principles which types of substances are indicators.
(In fact, just a few weeks ago, I found out that some types of wine can be used as indicators. I was washing some dishes and a red wine spot turned blue. Than I did a few other tests and confirmed this is the case. So the whole idea of "someone just accidentaly dropped litmus in acid and found out it changed color" is not as absurd as it may sound)
3)Litmus is red in acidic medium. You can turn it blue by adding base. You can turn it red again using acids. You can turn it blue again by adding base. You can turn it... You got the idea: when litmus is used in acidity/basicity tests, it's very simple to reverse its color.
When you use it for testing chlorine, however, litmus can't be brought to its original state. So litmus reacted with chlorine irreversably.
Remains to be said that lichens quite generally contain interesting dyes and that chromatography of these dyes is even used to distinguish species.
Some lichens were (and are) also used to dye cloth.
The fascination of medieval society with the color purple is likely the impetus for the experimentation with the extraction and production of litmus. At some point during manufacture, the dye contains both blue and red (purple) components in alkaline solution. This was http://www.ravensgard.org/gerekr/Orchil.html"
I would like to address the questions and concerns raised in this content. First, it is important to understand the basics of litmus and its function as a pH indicator. Litmus is a mixture of different dyes that are extracted from lichens, specifically Roccella tinctoria. These dyes are responsible for the color change seen in litmus paper when exposed to different pH levels.
To answer the first question, when the pH is outside the range of 4.5-8.3, the litmus paper will not give a clear indication of the pH. This is because the dyes used in litmus are only effective within this range. Outside of this range, the dyes may not change color or may give an inaccurate reading. This is why a universal indicator, which covers the full spectrum of pH, is used for a more accurate measurement.
The second question raises an important point about the discovery of litmus as a pH indicator. It was not a random accident, but rather a result of systematic experimentation and observation. In the 14th century, Spanish scientist Arnaldus de Villa Nova observed that lichens could be used to dye fabric and he noticed that they changed color when exposed to different substances. This led to the idea that lichens could potentially be used as indicators for acidity. Later, in the 16th century, German chemist Robert Boyle conducted experiments with lichens and acids, further solidifying the use of lichens as pH indicators.
Lastly, the statement from Wikipedia about irreversible reactions and chlorine gas is referring to the fact that the color change caused by chlorine gas is permanent and cannot be reversed. This means that the litmus paper would not be able to be used for further tests as the dyes have been permanently altered by the reaction with chlorine gas.
In conclusion, understanding the basics of litmus and its function as a pH indicator is important in order to fully comprehend its use in scientific experiments. It is also important to acknowledge the history and scientific discoveries that led to the use of lichens and dyes in litmus. As scientists, it is essential to always question and seek answers to deepen our understanding of the world around us.
1. What is the purpose of using lichens and dyes in litmus testing?
The purpose of using lichens and dyes in litmus testing is to determine the pH level of a substance. Lichens and dyes contain natural indicators that change color in response to different levels of acidity or alkalinity in a solution.
2. How does litmus testing work?
In litmus testing, lichens and dyes are first soaked in water to extract the natural indicators. Then, a small amount of the indicator solution is added to the substance being tested. The color change of the indicator indicates the pH level of the substance.
3. What are the different colors and their corresponding pH levels in litmus testing?
In litmus testing, red indicates acidity (pH level less than 7), blue indicates alkalinity (pH level greater than 7), and purple or violet indicates neutrality (pH level of 7).
4. Can litmus testing be used to determine the exact pH level of a substance?
No, litmus testing can only provide a general indication of the pH level of a substance. It cannot determine the exact pH level, but rather gives a range based on the color change of the indicator.
5. Are there any limitations to using lichens and dyes in litmus testing?
Yes, there are limitations to using lichens and dyes in litmus testing. The results may not be as accurate as using laboratory-grade pH indicators, as the natural indicators in lichens and dyes can be affected by external factors such as temperature and light. It is also important to note that some substances may not produce a clear color change with lichens and dyes, making it difficult to determine the pH level.
  • Biology and Medical
19K
164K
26K
9K
