Phase difference in CR and LR circuits
The discussion focuses on the phase difference in CR and LR circuits, particularly during an experiment involving a capacitor and resistor. Channel 1 of the CRO is connected across both components to avoid earthing channel 2, allowing for the observation of phase differences. The trace on channel 2 reflects the current through the capacitor because it measures voltage across the resistor, which is in phase with the current. Increasing resistance decreases the phase difference as it results in less current flowing, causing the capacitor to charge and discharge more quickly. Understanding these relationships is crucial for analyzing circuit behavior in both CR and LR configurations.
chris_yau
I have just done an experiment on CR and LR circuits.
http://img9.picsplace.to/img9/21/RC.jpg
Connect channel 1 of the CRO across both the capacitor and resistor and channel 2 across the resistor.The trace on channel 1 is taken as the p.d. across the capacitor and that on channel 2 as ths current throught the capacitor.
http://img9.picsplace.to/img9/21/RL.jpg
Replace the capacitor waith a high inductance coil fitted on a double C-core.
I have some questions about this.
Why is channel 1 is connected across both the capacitor and resistor and not only the capacitor?
Why the trace on channel 2 gives the current throught the capacitor?
When we increased the resistance value, the phase difference decreased.Why?
I have so many question to ask:confused: ..
I have thought about this today.
(1) The channel 2 will be earthed if channel 1 is only connected the capacitor. Thus, we cannot observe the trace 2 and cannot compare the phase difference.
(2) There is no phase difference between trace 2 and the current since this is the voltage across the resistor only. Therefore, trace 2 gives the current through the capacitor.
(3)I have no idea about the third question...:cry:
One of the leads of the oscilloscope is earthed. This means that one observe the potential differences at certain points in a circuit relative to earth. Channel 1 will thus in effect show the ouput voltage of the signal generator and channel 2 that of resistor, which in effect is the current in the circuit since the current through the resistor and the potential over a resistor is in phase - so your reasoning is correct since it is a series circuit.
Remember the what the RC charge - discharge curves look like? With a larger resistance less current flows in the circuit so the capacitor need to store less charge and will be on the parts of the curve where it "responds quicker" than if more charge would have been stored.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
