Photon Elapsed Time Equation: Calculating 24hrs
  • Thread starter Thread starter Doc Marino
    Photon Time
Doc Marino
Following the premise of Einstein, man cannot travel at light speed due to the overwhelming increase in mass during the hypothetical attempt. However, a photon has no such limitation... it travels at it's constant. Therefore, if a photon travels from the surface of the Earth into space (barring any possible variances from interference of any kind against it's constant), traveling outward for exactly 12 hours, then instantly reversing course and returning to the surface of the Earth (24 hours elapsed time measured at the photon), how much measured time will have elapsed on the surface of the earth?
You cannot measure the time elapsed for the photon, it is not in an inertial frame. If anything, you could compute the proper time of a light-like world line, which will give you zero by definition.
Doc Marino said:
...if a photon travels from the surface of the Earth into space (barring any possible variances from interference of any kind against it's constant), traveling outward for exactly 12 hours, then instantly reversing course and returning to the surface of the Earth (24 hours elapsed time measured at the photon), how much measured time will have elapsed on the surface of the earth?
There is no such thing as time measured at the photon. There's an FAQ entry here: https://www.physicsforums.com/threads/rest-frame-of-a-photon.511170/
[Edit: Rats! It looks like Orodruin beat me to it! No fair! He didn't stop to look up the URL of the FAQ! :)]
Hi Doc Marino, welcome to PF!
In technical language, I would interpret the phrase "time measured at X" to be "the proper time along X's worldline". This value is always 0, as was mentioned by Orodruin, meaning that it doesn't matter how long or how far the photon travels, it will never travel far enough to have even 1 nano-second "measured at the photon", let alone 12 hours.
Note, because of the consequences of the issue mentioned by Nugatory, it is problematic to interpret the length of a photon's worldline as a proper time. So even that interpretation of the phrase is a little sketchy when applied to a photon. I think that at some level you just have to recognize that certain operations which can be done on massive objects simply do not apply for massless objects.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
