Photon's disagree of the state of the universe?
  • Thread starter Thread starter JPBenowitz
    State Universe
JPBenowitz
So in modern physics we were going through SR and I had a question: since gravitational fields effect the amount of time elapsed and speed of a particle; say we have photon A emitted at the origin (0,0) and photon B emitted at (2,2) such that there is a uniformly decreasing gravitational field in both (T,x) and (T',x'). Photon A and Photon B wold disagree on the state of the universe such that Photon B would be traveling slightly faster then Photon A given they both travel slightly less than c. Is this true? Do observers O and O' disagree on the gravitational field relative to each other?
The thing about photons is that they don't travel faster than one another. No matter what observer measures their speed they will get the same value c. Even if the observer were traveling at the speed of a photon, the other photons would pass by at the measured speed of c.
SR takes as an assumption that c is a constant for all inertial frames of reference.
Gravity affects light by bending it or changing its energy. Blue light escaping from the vicinity of a black hole will not appear blue to a far away observer as its energy is reduced and its wavelength lengthened. The blue light will be red-shifted.
Instead of saying the photons "travel" slightly less than c can I say the gravitational field warps space-time in a manner that increases the distance between two points x and x_0 such that the photons arrive at x later than if ideally there was no gravitational field?
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
