Do Photons Have a Nucleus or Electrons?
Photons are fundamental particles without an atomic nucleus, protons, neutrons, or electrons, and they cannot be broken down further. They travel at the speed of light (c) because they are massless, and their motion is described by Maxwell's equations, which dictate that electromagnetic waves propagate at c. Spin and charge are distinct quantum properties that do not influence each other. When photons interact with atoms, they can transfer energy, causing the atoms to become excited, but they do not possess charge themselves. The interaction of photons with matter is probabilistic, and while they can pass through solid walls, their likelihood of doing so decreases with wall thickness.
Imparcticle
Do photons have an atomic nucleus with protons and neutrons and electrons? Does spin effect charge? Anything? Why do photons travel at c? Where do they get this power to travel at c from?
Science news on Phys.org
Photons are fundamental particles; they do not have any internal composition, and cannot be broken down into smaller pieces.
Spin is a different quantum number than is charge. They do not "affect" each other.
Photons travel at c because they are massless. Maxwell's equations of electromagnetism describe self-perpetuating oscillations in the electromagnetic field, and these oscillations must propagate at a specific velocity, c, to be self-perpetuating.
Photons do not need "power" to travel at c. Newton's first law indicates that an object in motion stays in motion unless acted upon by a force. A photon does not "propel" itself actively; it begins its life moving at c, and spends its entire life moving at c, until it hits something.
- Warren
Photons have enough energy to pass through a solid wall right?
How about strings?
Photons can pass through solid walls if they just happen to not interact with any of the atoms in the wall. The interaction of a photon with an atom is probabilistic; the best you can say is that a given photon has a certain chance of interacting with a given atom. If the wall is thick enough, the probability of interaction becomes very high, and very little light makes it through.
Strings are also indivisible, but they can change characteristics like modes of vibration. I am frankly not well-versed on string theory, however, so perhaps someone else can add more.
- Warren
What happens exactly, when a photon interacts with the atoms in a given solid wall? Is there a virtual particle interaction of some sort when they interact? In what sense does a photon interact with atoms making up a wall? does it get absorbed by atoms (so that the atom becomes a high energy atom for a given period of time)?
do photons have charge? I don't suppose so, since they aren't composed of any of the elementary particles.
The photon interacts with the atom by giving an atom enough energy to change from one "orbit" to another. Basically, the photon gives its energy to the atom, exciting it. The energy doesn't disappear, it's just turned into heat.
- Warren
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
