Photovoltaic vs. thermal radiator Solar Panel comparison (using a lens)
The discussion revolves around the comparison between photovoltaic (PV) solar panels and thermal radiator solar panels, particularly when both have the same collection area. Participants explore the efficiency, practicality, and potential applications of each type, including the use of lenses to focus energy on thermal panels.
  • Some participants note that PV panels are designed to generate electricity, while thermal panels are intended for heating water, making direct comparisons challenging.
  • There are claims that thermal panels could theoretically achieve around 30% efficiency compared to the 15-18% efficiency of PV panels, but practical challenges exist with thermal concentrators.
  • Concerns are raised about the practicality of using thermal panels for electricity generation, especially in colder climates where steam generation may be limited.
  • Some participants suggest that PV panels are more reliable in varying weather conditions, as they can still produce electricity on cloudy days, albeit at reduced output.
  • There is a discussion about the potential dangers of focusing solar energy, with references to severe burns from concentrated heat.
  • Participants express skepticism about the viability of thermal panels for DIY projects, suggesting they may be more suited for hobbyists rather than practical applications.
  • One participant proposes that focusing solar energy could improve the efficiency of thermal panels by increasing the temperature differential necessary for effective heat engine operation.
Participants generally express differing views on the practicality and efficiency of thermal versus photovoltaic panels. While some acknowledge the theoretical advantages of thermal panels, others emphasize the reliability and simplicity of PV systems, leading to an unresolved discussion on the best approach.
Participants mention various limitations related to the efficiency of thermal panels, including the need for high temperatures and the challenges of maintaining stable output. There are also references to the complexities of using steam and turbines for electricity generation, which may not be practical in all scenarios.
This discussion may be of interest to individuals exploring solar energy solutions, particularly those considering the trade-offs between photovoltaic and thermal systems, as well as DIY enthusiasts looking into solar panel projects.
camerart
Hi,
Has anyone experience with photovoltaic solar panels and thermal radiator type solar panels?
1/ How do they compare when both have the same collection area?
If the thermal radiator was much smaller than the collection area, and a lens the size of the collection area was used, focused on the radiator. This would produce the same amount of heat, but it would be hotter. Is there any advantage in this?
Cheers, Camerart.
Compare in which way? The purpose of one is to make electricity, and the other to heat water. That's pretty apples and oranges.
There are designs of both kinds of panels that use some kind of focus or concentration mechanism. Since none of them became popular commercially, I suspect that the answer was that simpler is better. For most people, "better" regarding these panels puts low weight on the area used.
Hi A,
The idea is to extract electricity from the thermal panels, by heat exchange, then a generator. I can see where inefficiencies may be, but there are also inefficiencies in PV.
Re 'better': I doubt they would go on roofs, so wight wouldn't be much of an issue, and they would need to be aimed. Also the focus distance is a bit inconvenient too.
I didn't know there are previous designs for focused panels, although I've seen mild focusing on roofs, but what I'm talking about is a much bigger ratio, thatn those.
C
In theory, on the 'thermal way' you might be able to reach around 30% efficiency, compared to the 15-18% efficiency of PV.
In reality, on the 'thermal way' concentrators (and with those: directioning of collectors) is required to have some ~ stable output and high efficiency, and that has plenty of drawbacks.
Also, size does matters. Small size means loss in efficiency (insulation is a difficult topic in itself, and you will need to work with high pressure steam, and find a small turbine too. And then the control - it's a nightmare).
PV in its simplicity is just a lot smoother game.
Random example:
These concentrators can cause really serious burns, by the way. Second or even third grade burns are just matter of momentary carelessness and done in seconds.
Hi R,
Thanks.
30% efficiency compared to 18% (at present?) is encouraging.
I'm not too worried about directioning, but can see many obstacles.
Is steamand turbines, the only way to convert the energy into electricity? I doubt there would be much steam generated in a UK winter :)
As for the dangers of focusing, I remember the ants of my childhood.
C.
At small size, not really. The truth is, that with all the trouble and in small size you'll be far (!) better of with PV.
This thermal stuff is good only as a hobby.
Also, at any time when there is any cloud or any obstacles to direct sunlight. PV works (albeit with less output) even in a cloudy day. At the end that'll matter more than the twice as big theoretical efficiency.
If you want a calm, comfortable life then just stay with PV.
If you need a DIY hobby for some hopeless but heroic struggle which burns away money like nothing then you can go on with the thermal thing.
Hi R,
The reason I asked the question was to save wasted time with frutless experimenting, so thanks, I'll forget it.
Before I do can I assume that you know what you're talking about?
C
I've seen many of these kind of DIY projects (when I tried to design my own).
In general they gives a good struggle, with really moderate reward.
Of course, if you keep the energy as heat (hot water for local usage) then that's a different kind of business.
That may work (depending on your location).
Hi R,
I suppose if the energy is for heating, then the standard panels would take the sting out of the heat difference whan heating a house in winter.
I've had lots of inventions over the years, all went the same way as this. (I was advised to stop)
Later, I'll post my engine design, which would have been ok, but electric is superceding it.
C.
It's not the only, but it is by far the most common and efficient way to turn heat into electricity.
camerart said:
Hi R,
C.
Solar thermal panels are very efficient in gathering heat to use as heat for your house or hot water but not very efficient to drive a heat engine to generate electricity because they are just not very hot and the maximum possible efficiency of a heat engine depends of the ratio of temperature of the hot side and cold side ##\eta = 1 - \frac{T_{cold}}{T_{hot}}##. Then it gets worse because of other inefficiencies in the system.
Hi B,
This is why I am suggesting focusing. This is to make the difference between the hot and cold sides a bigger ratio.
C
Here is an example of focused solar hot water panels.
Hi A,
This is better than my lens idea, it looks like it doesn't need to move to stay in focus?
I wonder why the collector tube isn't black?
C
camerart said:
Hi A,
C
Focused solar thermal panels have been well researched, well engineered, built and operated. Yet they are rarely seen today. What message does that suggest?
camerart said:
Hi B,
C
Of course but that is a whole different beast and also very dangerous if you are not careful. Also it can be expensive but still the efficiencies are likely to top out in the low 40's.
Erm... no. It's for having hot water, and not at winter, but from spring to autumn.
About solar heating: usually (depending on location!) the time when heating is needed and solar heating is actually available is just too short. This - again - is just a good DIY struggle without much return :frown:
Regarding heating, some passive solutions may be considered, but that's already architecture.
Consider some of these things instead. Relative easy to install, relative cheap (was cheap when I checked the prices last time), and can work from spring to autumn.
Some reserve system is still needed, though: and return depends on the location/climate.
Hi A,
It could mean that it isn't practical, or that they haven't figured it out yet.
C
Hi B,
Over the years, I've seen all sorts of things develop, in surprising ways. I remember milk floats, and look at electric cars now.
Generally power is dangerous.
Costs generally come down, apart from heating bills.
C
Hi R,
An interesting idea, but I won't be pursuing it.
Thanks all for you help in my decision.
Cheers, C.
That's a bit of a sweeping statement. Carbon neutral homes make very good use of Solar Thermal - sometimes just directly with south facing windows and effective blinds at night. PV has advantages but not so much when you can't rely on Feed-in Tariff (which is a bit of a snare and delusion)
We often talk about getting energy from the sun either as heat or electricity but It may be far more efficient to reflect heat in hot climates. I mean the effective cooling power of shade trees, cool roofs, radiant barriers as such. Even placing outdoor condenser units in shade rather than sun helps. On top of that good insulation helps to both keep cool and warm.
I saw today a presentation of geothermal systems for home or business and what made it efficient is that it has effectively the same efficiency whether the outside temp is 100 or 0. I was surprised to learn these systems still rely on compressors but they use the constant temperature of ground loop water flow to draw off the compressor heat rather than outside air temperature.
Hi S,
My house is definitely not carbon neutral, and can't be turned round easily. But when the sun shines here, it should be captured and stored somehow.
It's hot here at the moment, so any stored energy, should be converted to electric, for other uses than heating.
C
Hi B,
Effective cooling, should mean heat extraction, and strorage.
It wouldn't take much effort to use cooling from 'just' undergound, where the temperature is generally cooler.
Ground loop water is a special subject and needs studying and monitoring to see if there is enough cooling for what's needed.
General presentations, can be misleading!
C
Nope. It was a very specific reply in a very specific topic.
I'd agree with you, in that particular case but your sentence implied a more general criticism of thermal solar.
Looking at the various company ADs, there is some room for that too.
But here, it was very specific.
I appreciate that now. Perhaps just a few more words would be appropriate in posts on this sort of multi-faceted topic.
Hi S,
I agree with you. A snap reply, or a Google link, can be time consuming, and is impossible to know if the answer is from knowledge or a 2minute look up.
C
camerart said:
or a Google link,
I seldom appreciate post consisting of just a link. The information may well have passed through the poster's computer without touching the sides.
