Physical interpretation of this integral equation involving distance and time?
The discussion centers on the interpretation of the integral equation ##\int_0^x (1-t^2)/(1+t^2) \, dt##, particularly when considering ##x## as position and ##t## as time. Participants emphasize that while ##\frac{dx}{dt}## represents instantaneous change in position over time, the integral signifies a net change. It is concluded that not all calculus problems require a physical interpretation, and sometimes the mathematical formulation stands alone without direct application to physical concepts. The importance of distinguishing between dummy variables and defined variables in integrals is also highlighted.
  • Understanding of calculus concepts, specifically derivatives and integrals.
  • Familiarity with LaTeX for mathematical notation.
  • Knowledge of dummy variables in integration.
  • Basic principles of physics related to motion and change.
  • Explore the concept of dummy variables in calculus.
  • Study the applications of integrals in physics and engineering.
  • Learn about the relationship between derivatives and integrals in calculus.
  • Investigate the role of mathematical equations in various scientific disciplines.
Students and professionals in mathematics, physics, and engineering who seek to deepen their understanding of calculus and its applications, particularly in interpreting integral equations.
Irishdoug
I have been given a generic question, however I don't know how to interpret it if the variables had an assigned meaning.
f'(x) = ##\frac{d}{dx}## (##\int## ##\frac{1-t^2}{1+t^2}## *dt). The integral has the limits 0-x.
I am able to solve the problem however if x was position and t was time how is this problem interpreted?
I know, for example that ##\frac{dx}{dt}## tells us how the position of something changes as time changes (or instantaneous change) and an integral gives a net change so to speak.
You can easily write ##\int_0^x (1-t^2)/(1+t^2) \, dt##; just right-click on the image to see the LaTeX commands.
Anyway, why should ##f(x)## and/or ##f'(x)## have any particular "interpretation"? Maybe this is just a problem in calculus without any interpretation or without any relation to distance and time.
Im asking more so about the RHS of the equation. The reason I want to know how to interpret it as I do physics and equations require a physical interpretation.
If the integral arises in some "application" in physics, engineering, chemistry, biology, economics, ... then you may be able to come up with a reasonable interpretation. If it is just a calculus practice-example there may not be any interpretation, and you are wasting your time looking for one. It would be much, much better to just realize that calculus is a branch of mathematics that is widely applicable to numerous fields and situations, and that not everything need be related to physics. Equations definitely do NOT need a physical interpretation, although you may find it difficult to accept this. Basically, I am saying that you are hindering your own learning process by constantly trying to give a physical interpretation to everything. (I say this as somebody who earned a PhD in physics from MIT.)
Ok thanks for the heads up!
##t## looks more like a dummy integration variable here than time. For example, you can (almost) write:
##f(x) = \int_0^x g(x) dx##
But, technically, you are using ##x## as both the dummy integration variable and the variable for which your function is defined.
In general it's better to use different symbols for the two variables. For example:
##f(x) = \int_0^x g(x') dx' = \int_0^x g(u) du##
Or, in your case, ##t## is used as the dummy variable.
  • · Replies 105 ·
  • · Replies 24 ·
  • · Replies 22 ·
