Physics 117 problem about circuits and bulbs
  • Thread starter Thread starter VictorWutang
    Circuits Physics
When the switch in the circuit is closed, bulb A becomes brighter while bulb B goes out. This occurs because the switch creates a parallel path that bypasses bulb B, effectively short-circuiting it. As a result, the current flows primarily through bulb A, increasing its brightness. The voltage across bulb A increases when the switch is closed, contributing to its enhanced brightness. Ultimately, the current takes the path of least resistance, leading to the observed changes in bulb brightness.
VictorWutang
1. In the circuit shown below, describe what happens to the brightness of bulbs A and B when the switch is closed. Explain your reasoning. (no other information is given, just asking about the relative brightness of each bulb)
In the circuit, with the switch open, you have a loop with a battery and bulbs A and B in series. When the switch closes, B becomes parallel with the electrical line that holds the switch. In this case, the electrical line that B is on is inside of the larger loop of the battery, A, and the switch.
V = IR
I thought at first that the bulbs would both slightly dim because the added switch and line would add a small amount of resistance to the line, but I see that A gets brighter and B goes out. Is this because the current takes the path of least resistance and skips over the B bulb?
V = IR
Welcome to the PF.
I don't see your attachment...
I do not have a attachment for it, but i think i described it well enough.
Maybe this will help, tried to type it it best as possible. Ignore the asterisks, I just had to put them in there for spacing. The other lines are the wires.
|-----A-----------------|
emf **** B ***** switch
Hello
Does the diagram look like the image in the link?
http://img684.imageshack.us/img684/404/37304acd6959474e821ad8c.png
regards
Yukoel
yes, it does.
Yes, this is the reason why B goes out. The wire that has the switch in line with it acts as a "short circuit." It's called that because it gives the current a shorter path back to ground. Instead of having to go through both A and B, the current can now just pass through A and then directly to ground. So B has no current flowing through it: it has been "shorted out" of the circuit (i.e. bypassed).
Now all that is left for you to explain is why A gets brighter. Hint: what happens to the voltage across A when you close the switch?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
