Physics behind a fan based flying car concept
The discussion centers on the physics required to design a flying car using four fans to generate lift. Each fan, with a radius of 50 cm, must create a downward airflow sufficient to support a total weight of 1000 kg, assuming air density is 1.2 kg/m³. Participants explore the necessary downward speed of air and consider principles like pressure differences and angular momentum. The challenge lies in applying these concepts effectively to calculate the required airflow for lift. The conversation emphasizes the need for a clear understanding of the physics involved in achieving flight through fan propulsion.
PMsacr0sanct
For decades, people have dreamed of cars that can fly. You are part of a team which hopes
to build the worldʼs first commercial flying car.
Your proposed design has four fans, each of radius 50cm. Each fan sucks in air from above
the car and blows it downwards. The downward flow of air can be approximated as a column
of radius equal to that of the fan, traveling at a uniform speed downwards.
How fast must the air be blown downwards if the car plus passengers weigh 1000 kg?
You may assume that the density of air is 1.2 kg m-3.
I have considered pressure differences, and conservation of angular momentum, but I can't seem to apply them in any way that helps me solve for the required unknown.
Perhaps if you thought of the car as a rocket.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
