Physics frame of reference, is this possible?
The discussion revolves around the validity of changing the frame of reference in a collision problem. A participant proposes introducing a third object moving at 2 m/s to simplify calculations, claiming that this allows for easier manipulation of velocities. Responses confirm that using a new inertial frame is valid, as it enables the participant to derive final velocities correctly by adjusting for the reference frame. However, some caution is advised regarding potential misunderstandings in the details of the physics involved. Overall, the approach of using a different frame of reference is supported as a legitimate method in solving collision problems.
x86
Generic collision question.
For example, let's say you are asked the following question:
Object 1 is 10kg and is traveling at 10 m/s
Object 2 is 5kg and is traveling at 2 m/s
Find their final collisions after impact
m1v1 + m2v2 = m1vf1 + m2vf2
Ek1i + Ek2i = Ek1f + Ek2f
Ek = (1/2)mv^2
Now, instead of doing massive algebra and combining the two equations, can I include an object 3 into the scenario, and say it is going at 2 m/s
According to this new reference, object 1 will be going at 8 m/s and object 2 will be going at 0m/s and thereby be stationary.
Now, when I plugin values to the two equations, it gets a WHOLE lot easier because I can instantly cancel some values out and derive two new equations.
So, then I can say according to object 3, object 1 goes X m/s after collision, and object 2 goes Y m/s after collision.
Now, if i SUBTRACT the 2 m/s from object 1 and object 2, relative to the first reference I will get the final answers X+2 and Y+2 --> m/s
So, is this correct? Can I do this? Newtons laws state I should be able to, but my teacher said this is impossible and it doesn't work like that because I can't just add and subtract velocities. I said that all I'm doing is adding a reference point and removing it. I firmly think I can do this. If I can't do this, can someone explain why?​
Ek = (1/2)mv^2
What you are trying to do is valid. A couple of the details appear to be misstated, which may be what gives your teacher heartburn.​
What details am I mistaking? I would like to know so that I can understand physics more.
Thank you.
You do have object 2 traveling at V=v2=2 m/s to the right. What you do is introducing a frame of reference, traveling with 2 m/s to the right.
Correct
You can say that object 1 travels with velocity X m/s and object 2 travels with Y m/s after the collision, with respect to the frame of reference traveling with 2 m/s.
If you subtract the 2 m/s of any velocities with respect to the ground, you get the velocities with respect to the new frame of reference.
You are correct, the final answers for the velocities with respect to the ground are X+2 and Y+2.
You can use any initial frame of reference, and all frames of references traveling with constant velocities are inertial.
Anyway, you can derive the formulae for velocities without much algebra without introducing the new frame of reference.
If the initial velocities are v1 and v2, the final ones are u1 and u2, conservation of momentum and energy yield the equations
m1v1+m2v2=m1u1+m2u2
m1v12+m2v22=m1u12+m2u22
Rearrange
m1(v1-u1)=-m2(v2-u2) (1)
m1(v12-u12)=-m2(v22-u22) (2)
Factorise the second equation
m1(v1-u1)(v1+u1)=-m2(v2-u2)(v2+u2)
and divide by (1)
v1+u1=v2+u2 (3)
Together with (1), you have two simple equations to be solved. Multiply (3) with m1 and add to (1), solve for u2: u_2=\frac{2m_1v_1+(m_2-m_1)v_2}{m_1+m_2}
Exchanging the subscripts, you get the analogous equation for u1.
ehild​
