Physics Problem involving Kinematics
  • Thread starter Thread starter bbface_assassin
    Kinematics Physics
A typical car's brakes can achieve a maximum deceleration of less than 5 m/s², prompting a discussion on how close one can approach a stop sign before braking. The initial velocity is a crucial factor, and the problem can be expressed in terms of variables rather than specific numbers. The formula V² = Vo² + 2ax is applicable, allowing for the calculation of stopping distance in relation to initial speed and acceleration. Dimensional analysis can help estimate the braking distance, confirming that the solution can be derived mathematically. The conversation emphasizes the importance of understanding kinematic equations in solving such physics problems.
bbface_assassin
1) A typical car's brakes can create a maximum acceleration of less than 5 m/s2 . How
close can you get to a stop sign before you start braking?
I don't think it's even doable, since there's no initial velocity. Or am I wrong?
you are correct, sir. though, you could write the answer in terms of the unknown v_0.
Oh. So then my answer would be in variables, and not actual numbers?
yep. you can write the answer for the shortest braking distance in terms of the initial velocity and the acceleration... you might be able to guess it (up to a factor of 1/2) from dimensional analysis (i.e., looking at the units).
So can I use V^2 = Vo^2 + 2ax as the formula for solving this?
yeah, since you know what v has to be when the car has stopped. you can solve for x in terms of v0 and a.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
